6.0 Bad ficm, No codes - Ford Powerstroke Diesel Forum
post #1 of 8 Old 01-15-2014, 03:12 AM Thread Starter
For about six months now i've been dealing with an itermittant no start.It has pegressivly gottin worse. tested my ficm, its anwhere from 20v to 36v. I'm replacing it with BPD ficm. My ? is, since this problem started, no start, ruff running. low power. Not once has the mil light come on, and have scaned it several times and never got any codes.
Nospark918 is offline
post #2 of 8 Old 01-15-2014, 04:22 AM
Ford_Fan1's Avatar
Quoted: 6 Post(s)
Feedback Score: 3 reviews
There is usually a code but if not, don't worry about it. You know that its already bad so I would just replace it and go from there.
"Pickle Monster"
2004 F-350 King Ranch built 3/24/04
4" lift, 5" MBRP TB back exhaust
EGR MIA
,ported intake, 05-07 intake horn
CCSB
FX4
Firestone airbag suspension in the rear with on-board compressor
Monitored with Edge Insight CS, tuned by Gearhead
high idle mod, Atlas 40 FICM tune, Cat ELC,
2008 taillights, 08 mirrors, smoked marker lights, harpooned fuel tank, DIY headache rack, Bushwacker fender flares
Ford_Fan1 is offline
post #3 of 8 Old 01-15-2014, 05:04 AM
kinnisoj's Avatar
Quoted: 2 Post(s)
"what we have here....is a failure to communicate...."
I beleive one of the biggest mistakes that FORD did that led up to the 6.0 being such a PR nightmare was the lack of a good monitoring system. Or guages. Basiclly the truck rolled off the show room floor like a mute. And this lead up to the owners running down the road thinking life was good cause their was no lights on the dash that would of told them other wise.
Then the truck has a "all of the sudden it wont start" moment. And the owner is pizzed off and the word started to spread. But if the truck could of warned you it was in trouble months ago it would of been fixed before it was a major melt down event.
My ficm when I got the truck was running if I remember 41volts and without my Edge I would never have known it.
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
The Following User Says Thank You to kinnisoj For This Useful Post:
Heavy_GD (01-15-2014)
post #4 of 8 Old 01-15-2014, 01:43 PM Thread Starter
What on my truck detects or stores codes? Does the FICM do it, or do i have another problem?
post #5 of 8 Old 01-16-2014, 10:55 AM
aka MacGyver
rick1067's Avatar
No the FICM does not store codes. That comes from the trucks computer. Once the new FICM is installed you should be alright. If not come back and let us know.
rick1067 is offline
post #6 of 8 Old 01-16-2014, 11:45 AM
juzatheman's Avatar
If you replace whole fimc...
It is not common but trust me i been there you could have fimc logig boars issue and it doesn't cange a thing to just replace only the power board of yout fimc if the problem is on your fimc logic board..
juzatheman is offline
post #7 of 8 Old 01-22-2014, 08:09 PM
Yep, it's one of the "nicer" components that Ford left out (a.k.a. that little warning light, the ability to know when or when NOT to make a trip to the shop). I drove my 6.0 for about 3 months before it went all down hill and I forked over $2,000 in repairs. Luckily, and like I said "luckily", I have done alot of home work now with my little Scanguage 2.
rhillman75 is offline
post #8 of 8 Old 01-22-2014, 08:14 PM
JesseKK's Avatar
Quoted: 64 Post(s)
Garage
Scan gauge II ftw!
JesseKFK
2007 F250 XLT CC 6.0 PowerStroke FX4 R.I.P. 3.6.16
Livewire TS LOoNeY
Studded
BPD 58v FICM
BPD Oil&Egr Cooler
Glow Shift Pyro,Fuel
High Idle Mod UF#4
Fog Light Mod
Harpoon Mod
Dome Override Mod
6000k Bi-neon Hids
Sinister Coolant Filter
8in Rize Ind 4 link
35" Mickeys on 20s
Blue Leds
Power Service Every Fill Up
ATV 2008 Yamaha Raptor 700 FI
KCCO
Originally Posted by Karls03 View Post
I hate Edge power products so much, I quit using Edge shaving gel
JesseKK is offline
