Truck stalls out when high idle kicks in - Ford Powerstroke Diesel Forum
post #1 of 4 Old 01-15-2014, 02:02 AM Thread Starter
z7mathews6.0's Avatar
So yesterday morning went out start my truck to let it warm up, came back out and the truck was off. Did the same thing after work yesrerday to but it runs and drives fine. Its a 05 f250 just did a egr delete and oil cooler with a 3015 sct tuner with looney tune In it also have a ficm power supply that is suppose to be here Friday. could my low volts of ficm cause this with key on bolts are down to 40volts
4" MBRP Turbo Back exhaust
Bulletproof diesel 48v powersupply ficm
Sinster EGR Delete and new oil cooler
Sct sf3 tuner with looney tune
2.5 inch level kit and f350 rear blocks
Bilstein shocks all 4 corners
315/70/17 Hankook dynapro atms
2010 ford rims
08 tailgate
z7mathews6.0 is offline
post #2 of 4 Old 01-15-2014, 02:27 AM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
How cold is it where you are at? Before I replaced my FICM I had a few problems with stalling but it was only a few seconds after start up in cold weather... Below freezing.
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #3 of 4 Old 01-15-2014, 02:53 AM Thread Starter
Its 20 out right now and it started up and when high idle kicked in it shut off again, I removed the tune and started it again and it was fine no stalling the only code it brings up when tune is in it is p1000
2010 ford rims
08 tailgate
post #4 of 4 Old 01-15-2014, 02:45 PM Thread Starter
Talk to one of the techs from quick tricks tonight there gonna look into the tune but they ask if my act was updated and I thought it was but it wasn't I bet that was the issue
2010 ford rims
08 tailgate
