IPR PROBLEM - Ford Powerstroke Diesel Forum
post #1 of 6 Old 01-14-2014, 08:19 AM Thread Starter
KOOLTIM's Avatar
Angry IPR PROBLEM
I HAVE A 04 F350 6.0L AND I KEEP HAVING TO TAKE THE IPR VALVE OUT AND CLEAN OFF THE SCREEN. SOME TYPE OF RUBBER OR SILICONE MATERIAL WILL STOP THE FLOW OF OIL AND MY TRUCK WILL DIE. NOW I DO ALL MY OWN WORK AS I OWN A REPAIR SHOP, BUT I HAVE NEVER SEEN ANYTHING LIKE THIS IN THE MOTOR. I TOOK THE IPR TO THE LOCAL FORD DEALER AND THE DIESEL TECH SAID HE HAS NEVER SEEN THIS BEFORE EITHER. I DO KNOW THAT EARLY LAST YEAR I REPLACED THE OIL COOLER AND ALSO THE SCREEN UNDER THE COOLER, BUT I'M GUESSING THAT THE SCREEN IS BAD BECAUSE THAT FEEDS THE IPR. I DID JUST DRAIN MY OIL AND RAN IT THROUGH A SCREEN TO SEE IF IT WOULD CATCH ANYTHING AND NOTHING WAS THERE. I HAVE GOTTEN QUITE GOOD AT PULLING THE IPR TO CLEAN IT, BUT IT'S GETTING OLD REAL QUICK. ANY HELP WOULD BE MUCH APPRECIATED.
A HATER IS OUR BIGGEST FAN!
KOOLTIM is offline
post #2 of 6 Old 01-14-2014, 08:40 AM
information regurgitator
NYC F-350's Avatar
Quoted: 49 Post(s)
What BRAND oil cooler did you put in? The cheap Dorman oil cooler has a gasket set included in it that disintegrates in the presence of oil.. brilliant, I know..but true.
Is there something wrong with the caps lock on your keyboard?
Please
You could save the life of a sick child
NYC F-350 is offline
post #3 of 6 Old 01-14-2014, 08:46 AM
NYC F-350's Avatar
Quoted: 49 Post(s)
check out these links:
Dorman Oil Coolers
Beware of the Dorman Oil Cooler
03 6.0 with yellow rubber on ipr screen. - Ford Truck Enthusiasts Forums
Please
The Following User Says Thank You to NYC F-350 For This Useful Post:
KOOLTIM (01-14-2014)
post #4 of 6 Old 01-14-2014, 09:26 AM Thread Starter
KOOLTIM's Avatar
That has to be it. The replacement cooler was a Doorman part. Mines look brown but that could be from the oil I'm guessing. So just get the dealer seal kit and I should be good?
KOOLTIM is offline
post #5 of 6 Old 01-14-2014, 09:36 AM
Mod Newbie
dhanna6powerstroke's Avatar
Quoted: 20 Post(s)
If you're going in there again, you'd be better off to install an OEM cooler also.
dhanna6powerstroke is offline
post #6 of 6 Old 01-14-2014, 09:39 AM
NYC F-350's Avatar
Quoted: 49 Post(s)
Well, to be perfectly honest with you, and I was in your shoes, I would take the opportunity to put a real Ford (or International) part back in and ditch the cheap Chinese knock-off forever.
There is a member on here that bought the $80 Dorman oil cooler and a new Ford oil cooler to cut them both in half and compare them and is making a video.
He claims that the Dorman part has less cooling passages and that it is a poorly designed heat exchanger.
He will be posting that video on the forum (or so he has been saying for a couple days now..) showing the comparisons. He said this morning that he will be posting that video tonight. (yes, this is my way of urging him to "get 'er done!" if he sees this thread)..
There is another member here that has heard of the top studs getting pulled out of the top of the Dorman cooler, but couldn't find the thread that had the pics.
Please
