Need help stranded - Ford Powerstroke Diesel Forum
post #1 of 14 Old 01-13-2014, 03:21 PM Thread Starter
chris-rector's Avatar
Need help stranded
My trucks been running really well today I started it let it warm up took off is driving fine and I gave us some gas and it just died set there for a little bit cycle the key 3 times it would start run for about 10 seconds smoke pouring out of it even under the hood then it would die I can continue to do this and it does the same thing its an 03 it has I knew HPOP it has a new ICP I knew I PR also it has Warren 175 stock injectors in it that were just put in . Oil was changed last month
My IPR is 14.8 my fuel injection control module is going between 47.5 in 48 when I crank it my ICP is not reading nor does my sec read anything on my scan gauge 2
Anyone have any suggestions please I'm stuck
Thanks
<a href="http://truckprofile.com/members/chris-rector/Ford-F350-2003/694">My Truck Profile</a>
chris-rector is offline
post #2 of 14 Old 01-13-2014, 03:26 PM
DieselnDrums's Avatar
Do you smell oil? or see oil leaking any where?
06 f350, 6.0, 5 torqshift, egr delete, replaced oil cooler, SCT tuner, Head studs, MTW St 1 billet wheel, Custom tunes from GH.
DieselnDrums is offline
post #3 of 14 Old 01-13-2014, 03:28 PM
Huge Mythical Beast!!
LoxDiesel's Avatar
Quoted: 347 Post(s)
What color was the smoke
@loxdce
LoxDiesel is offline
post #4 of 14 Old 01-13-2014, 07:47 PM Thread Starter
So it will start if I cycle the keys . Bellows white or light grey smoke, smells like mad diesel fuel. once it is started it will idle and rev like everything is good. then all of the sudden it sounds like your slowly just turning the fuel down until the idle gets so low it dies. Thinking it could be a clogged converter, I pulled the down tube loose from the turbo just to see if it was the problem. When I pulled my hand back from the exhaust side of the turbo my fingers were covered with oil.
So how bad do you think it is?
post #5 of 14 Old 01-13-2014, 08:16 PM
Mod Newbie
dhanna6powerstroke's Avatar
Quoted: 20 Post(s)
Sounds to me like you've got at least one bad injector. Either a cracked nozzle or it's hanging open.
dhanna6powerstroke is offline
post #6 of 14 Old 01-13-2014, 08:23 PM Thread Starter
Man I was afraid someone was going to say that. I did get a contribution error on #1 one time.
post #7 of 14 Old 01-13-2014, 08:27 PM
Mod Newbie
Quoted: 20 Post(s)
I'd bet money that's the issue. I had that happen on an 06 I put injectors in just a few months ago. #6 contribution and ended up being a cracked nozzle.
post #8 of 14 Old 01-13-2014, 08:38 PM Thread Starter
well I just put these in maybe a month and a half ago. I got them from Warrens but I was going to get bigger nozzles I was just hoping to wait until I bought a new turbo
Why would I have oil in my exhaust port/down tube.
post #9 of 14 Old 01-13-2014, 08:40 PM
Mod Newbie
Quoted: 20 Post(s)
Could have a seal leaking in the turbo. The injectors I put in were in one day when the nozzle cracked.
post #10 of 14 Old 01-13-2014, 08:57 PM Thread Starter
weather permitting Im going to pull it apart tomorrow See whats what I suppose
