issue - Ford Powerstroke Diesel Forum
post #1 of 3 Old 01-13-2014, 04:30 AM Thread Starter
issue
Just got a cts and plugged it in. Right off the bat I got a ficm alert and looks to be like a injector power/pressure ???? I'm aware the ficm needs replaced as it was 30-35% until about 10 minutes into the drive, but confused on the IPR. It's showing anywhere from 33-41% and acceleration seems pretty sluggish. Is this, injectors giving out or the pressure regulator? Help!
Edit: no smoking and seems to be starting fine. Cranks for about 1-2 seconds then fires up. It's my 1st diesel so not sure what to look for.
Cru6614 is offline
post #2 of 3 Old 01-13-2014, 05:02 AM
kinnisoj's Avatar
Quoted: 2 Post(s)
If you FICM is showing 33-41 volts then I would suggest you dont run the motor any more than possible until you adress this. Low voltage on the ficm is anything below 45v.
And a weak ficm is hard on injectors.
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
The Following User Says Thank You to kinnisoj For This Useful Post:
Heavy_GD (01-13-2014)
post #3 of 3 Old 01-13-2014, 06:13 AM Thread Starter
Would that explain the low % of IPR on my monitor? Or is that seperate
Cru6614 is offline
