After EGR cooler and Oil Cooler, ran but now dead? - Ford Powerstroke Diesel Forum
post #1 of 6 Old 01-12-2014, 05:53 PM Thread Starter
2005
6.0
F250
225K miles
Blowing white smoke. Replaced EGR Cooler, and Oil Cooler. Fresh oil and coolant. Started and RPM up to 2,000 (left over brake clean from cleaning tubing, etc?)
Started 2nd time, RPM 800, idled poorly for a few seconds. Blimped throttle, and RPM jumped again.
Started 3rd time, RPM 800, idle started to smooth out. Started process of adding coolant to degas bottle. 4 gallons of coolant and water into bottle. RPM steady, starting to clean out, smooth out.
Sitting in side, oil pressure gauge was at 75% on gauge. Truck dies. Attempted restart = no go.
Opened fuel filter housing next day, empty. Guessed out of fuel. Added fuel, turned over, and plenty of fuel in filter housing.
Runs for a few seconds on a LITTLE shot of starting fluid.
No oil pressure when cranking, and oil filter housing is empty. Filter is moist, but not swimming like I think it should.
Research gives me a bunch of acronyms... ICP, IPR, etc?
HELP, please? I need this thing to run.
Thank you!
Zach
Backtobasics is offline
post #2 of 6 Old 01-12-2014, 06:34 PM
information regurgitator
NYC F-350's Avatar
Quoted: 49 Post(s)
The oil filter housing will always be empty when you open it.. There is a valve on the bottom of the housing that opens when you crack open the cover and drains the housing into the oilpan.
Remove the filter. look for the black plastic poppit valve in the bottom of the housing, using a long handled screwdriver, hold that valve down and crank the engine over..the housing should fill quickly.
Take the fuel filter out of the housing on top of the engine, have someone turn the key on..that housing should fill quickly.
Please
You could save the life of a sick child
NYC F-350 is offline
post #3 of 6 Old 01-12-2014, 06:56 PM
Powerstroke Techie
Quoted: 13 Post(s)
Garage
Feedback Score: 4 reviews
Typically it's an IPR contamination problem that results after an oil cooler repair. Debris gets down into the oil cooler reservoir passage and punches its way through the screen clogging up the valve.
-Matt
Ford Senior Master Tech
2015 F-250 XLT 6.7L
2006 F-250 6.0L SOLD
sinner6.0L is offline
post #4 of 6 Old 01-12-2014, 07:02 PM Thread Starter
Can you elaborate on the IPR, what and where it is located?
post #5 of 6 Old 01-16-2014, 01:27 PM Thread Starter
Replaced IPR and cleaned turbo.
Runs for 3-5 minutes, and dies. Idle blips 1-3 times during this time, blips up, then back to normal.
I don't trust it to pull it out of the driveway. Anything in particular I should be looking for?
post #6 of 6 Old 01-16-2014, 01:35 PM
Huge Mythical Beast!!
LoxDiesel's Avatar
Quoted: 349 Post(s)
I know its a shot in the dark with that many miles on it but do you know if it still has the factory STC fitting on the hpop? Sound like the oil thins out, it dies and doesn't restart. That tells me its a high pressure oil leak.
@loxdce
LoxDiesel is online now
