Chugging and blowing black smoke - Ford Powerstroke Diesel Forum
post #1 of 11 Old 01-12-2014, 10:41 AM Thread Starter
Well guys I was right down the road from my girlfriends dad's house. And my truck went to chugging and blowing black smoke, I got diesel 2 days ago. Have drove it a little bit but not much. Is it possible that I could've got some bad diesel that has water in it or something? Anybody else have this problem? Please help. thanks guys!!
HardcoreFx4 is offline
post #2 of 11 Old 01-12-2014, 10:59 AM
Bluedemon6.0's Avatar
Send a message via Skype™ to Bluedemon6.0
It could be bad fuel, you can drain your water separator and look for contamination. Have you checked your ficm voltage to see what it is reading with a multimeter? If not you can google ficm voltage check and find some links. This what I would try first. You can also check the map sensor hose for damage or clogs. This is located on the passenger side of the motor just above the evaporator and the hose goes down to the intake remove and clear any obstructions. Keep us posted .
-Steven
New!! 2015 Mustang ecoboost!!
Sold!!
formally owned:04 6L PSD CCSB
Studs
Egr delete
S&b intake
New dashboss with fuel pressure and egt
Sct Looney by Vivian and Tonywildman xtreme early lock up now
php 140x
63.5/88mm 06 turbo with a pmax billet WW2
PHP Atlas 80
My baby-
87 jeep wrangler
350 and 700r4 built by mad dawg transmission
Dyno @ 200hp and 400ftlb at 3100 rpm
On 33s
Bluedemon6.0 is offline
post #3 of 11 Old 01-12-2014, 11:02 AM Thread Starter
No I haven checked the ficm. I don't really no nothen about these to be honest, I was searching on google and saw something about an egr valve being wet causing same issue so I pulled the wire off mine and it is wet. Also saw something about the turbo. Hope it's not that.
post #4 of 11 Old 01-12-2014, 11:12 AM
It could be a an egr valve as we'll pull it and clean if intake is wet it could be a blown egr cooler but I'm not familiar with that at all. I do know that if your egr valve is sticking it would cause the symptoms that you are describing.
-Steven
Sold!!
Studs
Egr delete
S&b intake
php 140x
PHP Atlas 80
My baby-
87 jeep wrangler
On 33s
post #5 of 11 Old 01-14-2014, 01:28 PM Thread Starter
Well I pulled the egr valve has some pretty good carbon on it, but it didn't look to be stuck opened. Before I start the truck I looked into the hole with a flashlight and it was dry then started it. It had a little bit of water like residue, I put my ratchet In there to get a little of it and it looked almost like tar, haven't got to clean the valve and install yet but will probably do tomorrow.
post #6 of 11 Old 01-19-2014, 06:25 AM Thread Starter
well i found my problem, i had my girlfriends dad and uncle look at it and drive it, and they are diesel mechanics, and they both said it was a boost leak so i popped the hood and he found the little hose coming from the turbo and it was split so i got that fixed and it still did it so we unplugged the egr valve and it ran great!!!!
post #7 of 11 Old 01-19-2014, 06:39 AM
Glad to hear, so you are replacing the egr valve right or deleting the cooler and valve. I would suggest if you don't live in a state that has emission laws i would delete the egr cooler and valve. Egr valve are know to fail often, just a thought.
-Steven
Sold!!
Studs
Egr delete
S&b intake
php 140x
PHP Atlas 80
My baby-
87 jeep wrangler
On 33s
post #8 of 11 Old 01-19-2014, 07:07 AM Thread Starter
Yeah thanks man, and im just gonna leave it unplugged for now cause I was reading on the net and it said it wouldnt do no harm, and mabey do a egr delete and new oil cooler a little later down the line. Just want to make sure nothings gonna go wrong. Cause if it does im just gonna have to trade it off and go back to gas.
post #9 of 11 Old 01-19-2014, 01:58 PM
Powerstroke Techie
Lilpooh's Avatar
Feedback Score: 3 reviews
The issue you might have with the 03 and unplugged EGR valve will depend on the PCM strategy. The later VXAP1 and VXAP2 strategies with the valve unplugged causes the VGT to not go thru the VGT vane sweep cycle at idle. Other possible issues may be fan not reaching full RPM when commanded.
Sent from AutoGuide.com App
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
post #10 of 11 Old 01-19-2014, 02:54 PM
I agree with Lilpooh there has to be some function to the egr valve, it can not be good to disconnect it without deleting the egr cooler but that is just me.
-Steven
Sold!!
Studs
Egr delete
S&b intake
php 140x
PHP Atlas 80
My baby-
87 jeep wrangler
On 33s
