Slow Crank, No Start - Ford Powerstroke Diesel Forum
post #1 of 23 Old 01-11-2014, 01:48 PM Thread Starter
Korx's Avatar
Hey guys looking for some help on a 06 6.0 that I'm working on. The issue is that it will hardly crank. Guy says that the truck just shut off and wouldn't start back up. When I say slow crank I mean extremely slow to the point where it barely moves the engine, and obviously not starting at those speeds.
What I have done so far, replaced batteries with 2 brand new batteries, replaced the starter twice to ensure I didn't get a bad one, pulled off the belt and checked all pulleys all seemed OK, A/C compressor isn't locked up, tried cranking it without the belt and there was almost no difference in cranking speed - still extremely slow, tried changing the whole FICM, unplugging the crank position sensor and plugging it in, and that's about it no difference. The only thing I can think of is wiring to the starter or maybe the motors gone.. I am stumped.
Looking for some opinions of ideas of what it could possibly be or some help to get this thing spinning over at least.
Korx is offline
post #2 of 23 Old 01-11-2014, 02:00 PM
C_Healy0360's Avatar
Could be a lot of things. The next thing I would do is pull the glow plugs and crank it to see if there's any water in the cylinders
C_Healy0360 is offline
post #3 of 23 Old 01-11-2014, 02:51 PM
Try turning the motor by hand with a ratchet see if engine components are in a bind
Lord I shall lead them to the water but I will not try to make them drink
dannyboy950 is offline
post #4 of 23 Old 01-11-2014, 02:57 PM Thread Starter
Korx's Avatar
Tried cranking it over by hand. Moves almost too easy. Way easier than my 6.0 does when I crank it over by hand. I almost would say it doesn't have much compression but that would make me believe that it would just spin right over? Correct me if I'm wrong
2004 6.0L F-250 XLT - ECSB
CTS SCT
Deleted
Studded
5" Exhaust
175cc Injectors
1995 7.3L 5-Speed F-350 XL Dump
Stock
Korx is offline
post #5 of 23 Old 01-11-2014, 04:23 PM
Well that eliminates bottom end drag problems. What kind of volt/amp draw down are you getting on the batteries? Compression, hydrolock problems next thing to check.
post #6 of 23 Old 01-11-2014, 04:32 PM
Bluedemon6.0's Avatar
Send a message via Skype™ to Bluedemon6.0
Any smoke? Have you checked coolant pressure? when my hgs went out it would hydrolock the motor but I could open the degas cap and relieve pressure. Idk?
-Steven
New!! 2015 Mustang ecoboost!!
Sold!!
formally owned:04 6L PSD CCSB
Studs
Egr delete
S&b intake
New dashboss with fuel pressure and egt
Sct Looney by Vivian and Tonywildman xtreme early lock up now
php 140x
63.5/88mm 06 turbo with a pmax billet WW2
PHP Atlas 80
My baby-
87 jeep wrangler
350 and 700r4 built by mad dawg transmission
Dyno @ 200hp and 400ftlb at 3100 rpm
On 33s
Bluedemon6.0 is offline
post #7 of 23 Old 01-11-2014, 05:26 PM Thread Starter
Korx's Avatar
Thing doesn't even crank at high enough RPMs for it to smoke it cranks at like 2 RPMs.
CTS SCT
Deleted
Studded
5" Exhaust
175cc Injectors
Stock
Korx is offline
post #8 of 23 Old 01-11-2014, 05:28 PM Thread Starter
Korx's Avatar
Did a voltage drop test on the batteries and starter and everything seemed normal. I am thinking it is a compression issue, it just seems way too easy to crank turn by hand
CTS SCT
Deleted
Studded
5" Exhaust
175cc Injectors
Stock
Korx is offline
post #9 of 23 Old 01-14-2014, 07:16 AM
AshevilleEngine.com's Avatar
Quoted: 2 Post(s)
When I first read your post I was thinking poor maintenace led to spun bearings but when you post that it turns over by hand "too easy", that has me totally stumped. I can't imagine that it's a hydrolock issue because that should make it impossible to turn. I would pull the glow plugs just to see how it cranks with no compression at all.
AshevilleEngine.com is offline
post #10 of 23 Old 01-14-2014, 08:44 AM
Heavy_GD's Avatar
Quoted: 1326 Post(s)
Feedback Score: 3 reviews
I've hear bad a/c compressors causing slow crank, also heard stand pipes causing not start.
GD
Originally Posted by 6.0Stroker View Post
It's Toren. .. don't question it ..
Heavy_GD is offline
