Help!!! Fuel filter change no start - Ford Powerstroke Diesel Forum
post #1 of 7 Old 01-10-2014, 02:46 PM Thread Starter
southern7.3's Avatar
Change the upper and lower filters with motorcraft filters. Cranked up ran fine then started skipping lost power and cut off. Purged it like we were suppose to. Took the top filter off hit the key and nothing no fuel.
What's up with it?
It's raining and I'm outside
Sam
2005 F350 King Ranch CC DRW Insight Leveled 4" MBRP Straight Pipe Tinted
'99 F250 - Sold
'99 Cummins - Sold
southern7.3 is offline
post #2 of 7 Old 01-10-2014, 03:17 PM Thread Starter
Bump. .
Sam
'99 F250 - Sold
'99 Cummins - Sold
post #3 of 7 Old 01-10-2014, 03:31 PM Thread Starter
Update got fuel in the top filter still nothing
Sam
'99 F250 - Sold
'99 Cummins - Sold
post #4 of 7 Old 01-10-2014, 05:27 PM
I have always cycled the key three times after a filter change and had no problem. Did you prime like this?
kyle23462 is offline
post #5 of 7 Old 01-11-2014, 01:29 PM
midnite rider's Avatar
Quoted: 285 Post(s)
try blowing air through lines coming from tank may have blockage in line
-Tom
05 250 KING RANCH CCSB,278k,ARP's,SCT TSX,Atlas 40,STC done,Glowshift FP Gauge,Banks IC System,Blue Spring,Banjo's,CCV mod,Oil Bypass,Diamond Eye 5" Exhaust,Bilstein 5100's,RC Dual Steering Stabilizer,Retro 55W 6k Heads 3k Fogs,Continental Airbags,RSD 48 gal Aux Fuel Tank.
2003 F350 Lariat CCSB, 288K, Everything But Studs.
midnite rider is offline
post #6 of 7 Old 01-12-2014, 12:06 PM
PlatinumDiesel's Avatar
Key on 10 seconds, key off. Repeat 5/6 times.., she will go
Sent from AutoGuide.com App
PlatinumDiesel is offline
post #7 of 7 Old 01-14-2014, 05:36 AM
AshevilleEngine.com's Avatar
Quoted: 2 Post(s)
Did you replace your filters with Ford OEM? If not, that's probably your problem, a lot of trucks don't do well with aftermarket fuel filters.
AshevilleEngine.com is offline
