Icp air leak test fitting size? - Ford Powerstroke Diesel Forum
post #1 of 5 Old 01-09-2014, 05:12 PM Thread Starter
I need to know the size if the ICP sensor so I can get a fitting to air leak test the HPOP system. Any suggestions before I start?
tkeith87 is offline
post #2 of 5 Old 01-10-2014, 07:24 AM
mrenn's Avatar
Quoted: 3 Post(s)
See if this video will help.
ARP,EGR Delete,SCT,4.56 gears,powermax,Banks Techni-cooler,Adrenalin HPOP,Donohoe springs,fox shocks,airbags,blue spring,38x15.5 M. Thompson's,4 10's,2 tv's,playstation,amp-steps,2013 tailgate,edge cts
2016 Lariat 6.7.
mrenn is offline
post #3 of 5 Old 01-11-2014, 05:37 AM
M12 x 1.5. It's the same as the fuel pressure test port. I keep an single adapter in my box for both.
sdb999 is offline
post #4 of 5 Old 01-12-2014, 12:10 PM
PlatinumDiesel's Avatar
Bulletproofdiesel.com sells the fittings for $30... Finding the fitting with an o ring and a fitting that's long enough to thread in properly is not gonna happen... Find a lathe if not
Sent from AutoGuide.com App
PlatinumDiesel is offline
post #5 of 5 Old 01-12-2014, 06:42 PM
Not really most hydraulic shops that sells fittings can get an adapter with oring for $12.
Lord I shall lead them to the water but I will not try to make them drink
dannyboy950 is offline
