Blown head gasket? - Ford Powerstroke Diesel Forum
post #1 of 19 Old 01-07-2014, 04:09 PM Thread Starter
Blown head gasket?
Sorry for the long post
I have a 05 f250 I recently purchased, truck runs great and up until now completely stock. I was doing dome reading and decided to put a new coolant cap on it a few weeks ago just to be safe. I'm here in Ohio and it's been pretty cold to say the least (with windchill in the -40 range) The truck didn't have a block heater cord on it so I bought one and put it on a week ago. The truck never fails to start at all, anyways. I did a lift kit and wheels on it and yesterday I decided to put my live wire tuner on it, I put a street tune with a tire size change. I started the truck and immediately noticed a lot more smoke just idling there, figure its -10 out it's to be expected. I had to make a run so I drove on the interstate and noticed in the mirror it seems to be smoking but figured it was the weather, never beat on it or anything, after it was warm at idle there was no smoke when idling. Parked it last night and plugged it in, started it this morning and let it run for probably 45 minutes before I left to work. Got almost to work and sitting at a light I noticed sitting at idle I had no heat but soon as I take off from the light heat was back? Popped the hood when I got to work and saw that there was coolant around the coolant cap and everywhere around it and coolant was at the minimum line. Where should I go from here?
Also rethinking this a bit, The day I did the tuner, on my way to work before installing it I was on the interstate and looked down and my boost was showing around 25-28 psi just cruising down the interstate. I scanned it before installing the tuner and had a p0611, p0674 and p0299 code, I cleared them and the p0299 code hasn't come back and noticed on the interstate tonight was showing 5-10 psi cruising?
tking7 is offline
post #2 of 19 Old 01-07-2014, 04:45 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
Is your egr still hooked up?
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #3 of 19 Old 01-07-2014, 04:51 PM
Mathes's Avatar
I second the egr check but sounds like my exact concern when my head gaskets where blown. sorry to say. and your boost numbers are normal.
03 build in progress
Mathes is offline
post #4 of 19 Old 01-07-2014, 05:54 PM Thread Starter
yes the egr is still on, completely stock except has a tuner
tking7 is offline
post #5 of 19 Old 01-07-2014, 06:02 PM
Mathes's Avatar
Next step to me would be checking to see if the egr cooler is blown. Pull the egr and look for coolant in the intake.
Mathes is offline
post #6 of 19 Old 01-07-2014, 06:30 PM Thread Starter
I will pull the egr tomorrow and check
tking7 is offline
post #7 of 19 Old 01-09-2014, 09:09 AM Thread Starter
I pulled my egr off today and it is definitely wet inside the intake.
tking7 is offline
post #8 of 19 Old 01-09-2014, 09:22 AM Thread Starter
tking7 is offline
post #9 of 19 Old 01-09-2014, 11:27 AM
Mathes's Avatar
Looks like you for sure have a blown egr cooler. I would start there as thats cheaper than doing it all at once but whatever you want to do.
Mathes is offline
post #10 of 19 Old 01-09-2014, 11:28 AM Thread Starter
What are the chances of it just being the EGR cooler and not the head gaskets. I have an EGR delete kit sitting here ready to go on but don't really want to go through that if I have to turn around and do the gaskets in a week.
tking7 is offline
