03 Misfiring and Stalls when driving - Ford Powerstroke Diesel Forum
post #1 of 11 Old 01-07-2014, 09:32 AM Thread Starter
charliebayne's Avatar
Exclamation 03 Misfiring and Stalls when driving
Well I'm in Northwest Indiana where we are having -45 wind chill and yesterday I had to run to our TSC to get some straps. My Truck was plugged in, and I let her warm up for 35 minutes before I drove. Oil and Coolant temps were right around 140 when started driving. I have added a bottle of Diesel kleen to keep from gelling also. Went out and drove and I noticed a little loss of power and then it seemed ok where I was back to normal. 2 Miles later I couldn't go above 25 and I could tell that it was misfiring and sounded strange. Is it just because of the extreme cold that it is doing this or is it something else? I haven't drove it today because it is still about -25 and figured ill mess with it in the coming days when it is warmer out.
charliebayne is offline
post #2 of 11 Old 01-07-2014, 01:40 PM
well it does sound like a fuel pressure issue. i would assume it would be because of the cold, but then again i live in florida and the coldest it gets here is 65.
jeby64 is offline
post #3 of 11 Old 01-07-2014, 01:43 PM
RADIOFLYER's Avatar
What modifications do you have done to the truck? IE any type of aftermarket lift pump and what not? Any codes?
I agree it sounds like fuel related.
How much diesel kleen did you put into the tank with how much fuel?
What color was the diesel kleen bottle?
2008 F-250
578HP/1188TQ
JUST ANOTHER FORD
RADIOFLYER is offline
post #4 of 11 Old 01-07-2014, 03:05 PM Thread Starter
I have 4 inch lift with 37s, K&N intake, magna flow exhuast, SCT livewire with custom tunes, zoodad mod, blue spring mod, and ficm, injectors were replaced 30k ago. I have 214k on the truck and haven't had any problems recently. It was the white bottle for 40 gallons so I put it all in except for a couple ounces.
post #5 of 11 Old 01-07-2014, 03:06 PM Thread Starter
Fuel pump was replaced 30k ago with new ford pump. No codes either
post #6 of 11 Old 01-08-2014, 07:41 AM
RADIOFLYER's Avatar
I'd hook a scanner up to it and look at your ICP and IPR...maybe even your FICM voltage. Just to be safe. I believe you can check some of those with a Livewire but don't quote me on that.
2008 F-250
578HP/1188TQ
JUST ANOTHER FORD
post #7 of 11 Old 01-08-2014, 08:21 AM Thread Starter
Ok I'll do that, I was gonn take her out today and see if any Better since it's abut 15 today. Also I replaced the icp sensor about 15k ago and ford replaced IPR 30k ago.
post #8 of 11 Old 01-08-2014, 03:08 PM
lostparrot's Avatar
injectors
mine just did the same thing. lost power as i was driving, then stalled. then started back up, but with almost no power. finally wouldn't start. the fuel jelled, and fried the injectors. good luck!
Not all who wander are lost
2005 Excursion 6.0 diesel. eddie bauer.
lostparrot is offline
post #9 of 11 Old 01-08-2014, 04:24 PM Thread Starter
Yeah I drove about 1 hour 1/2 today no problems at all. Guessing just the cold weather did it
post #10 of 11 Old 01-08-2014, 05:36 PM
midnite rider's Avatar
Quoted: 285 Post(s)
fuel gelled pull seperator filter that will tell the story
-Tom
05 250 KING RANCH CCSB,278k,ARP's,SCT TSX,Atlas 40,STC done,Glowshift FP Gauge,Banks IC System,Blue Spring,Banjo's,CCV mod,Oil Bypass,Diamond Eye 5" Exhaust,Bilstein 5100's,RC Dual Steering Stabilizer,Retro 55W 6k Heads 3k Fogs,Continental Airbags,RSD 48 gal Aux Fuel Tank.
2003 F350 Lariat CCSB, 288K, Everything But Studs.
midnite rider is offline
