Bad FICM? - Ford Powerstroke Diesel Forum
post #1 of 7 Old 01-07-2014, 04:39 AM Thread Starter
Bad FICM?
Hi All,
I am a new Powerstroke owner who just recently purchased a 2004 F-350 4X4 CCLB Lariat. However I have a question. It has been cold here over the last few day, to the tune of 17 degrees. I notice that when its warmer, say 40 degrees plus, that I can hear my injectors chatter before I start the truck. Now, after I let the glow plugs cycle, I hear no chatter. The truck will start, but it has a high pitched "puny" sound compared to the harder hitting sound I get when it is warmer outside. My guess is that I might have a FICM going bad, but I'm not sure if its just because its cold outside or not. I hope I have done an adequate job of explaining the problem. Thanks in advance for any advice!
katiladan is offline
post #2 of 7 Old 01-07-2014, 04:53 AM
kinnisoj's Avatar
Quoted: 2 Post(s)
Welcome to the site! If you dont have a monitor then you are truely guessing as you stated. A good monitor is a must.
Im gonna just assume the diffrence you are hearing is the thickness of the oil. When its cooler outside the oil the oil is thicker and the injectors/motor is quieter upon start up.
What oil are you running?
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #3 of 7 Old 01-07-2014, 05:06 AM Thread Starter
Hey kinnisoj,
Thanks for the reply. I'm not sure on the oil. Like I said, I just purchased it so I have not had an opportunity to change the oil yet. The man I purchased it from had it changed right before I bought it. What you are saying makes sense. The truck runs fine when I am out on the road and I always let it warm up to operating temperature before driving. Once its started, it runs smooth. What oil do you suggest? I have read several strings about several brands. Seems a Rotella-D full synthetic is pretty popular. Do you have any suggestions on what kind of monitor to buy?
post #4 of 7 Old 01-07-2014, 05:18 AM
aka MacGyver
rick1067's Avatar
Originally Posted by katiladan View Post
Hey kinnisoj,
katiladan, also ensure you run some type of additive in the oil and fuel. This will prevent other issues that could arise. To check the FICM without any type of monitoring equipment, check out this video;
Also do some research as to what type of monitoring system would best fit your needs.
rick1067 is offline
post #5 of 7 Old 01-08-2014, 10:41 AM
op i also just had my PSD cherry popped. I am taking everything step by step based on what I can afford at the time. I recently just bought an Edge CTS and hopefully will have it by tomorrow to play with it this weekend. I didn't mind the price because its big, touchscreen, and i can hook up a back up cam and egt probe to it in the future. Others say the scangaugeII is a good buy for a really good price for starters, but like i said money wasn't an option at this time. Some really good articles on the site and a couple of them about fuel additives and oil. I will be going to walmart today and buying some tcwIII 2 stroke and will add just that on my fill up tomorrow and then next fill up i will add just a fuel additive (diesel kleen/optilube seems to be the most popular) and then both the next one and compare. Its rough being a noob to PSD because if your like me every noise, clank, even long cranking tends to worry me. It has taken everything not to sit here and create 40 threads with all the questions i have.
Cru6614 is offline
post #6 of 7 Old 01-08-2014, 11:36 AM
mrenn's Avatar
Quoted: 3 Post(s)
If you are somewhat mechanically inclined and have a voltage meter.Watch this video.
ARP,EGR Delete,SCT,4.56 gears,powermax,Banks Techni-cooler,Adrenalin HPOP,Donohoe springs,fox shocks,airbags,blue spring,38x15.5 M. Thompson's,4 10's,2 tv's,playstation,amp-steps,2013 tailgate,edge cts
2016 Lariat 6.7.
mrenn is offline
post #7 of 7 Old 01-08-2014, 01:51 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
Hey kinnisoj,
I runt the Rotella t6 with a helping of Archoil. I run the Rotella because its easy to find at any wal mart. And I ran the Archoil after doing a bit of research here on the site. And man o man the truck just seemed to reeley do so much better with it. Well heck ever since I did this and got my FICM up and healthy I havent needed to plug the truck in since.
,edge turbo timer
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
