Best Torque App Screen to monitor 6.0 Vitals - Ford Powerstroke Diesel Forum
 3Likes
post #1 of 39 Old 01-06-2014, 02:54 PM Thread Starter
mad103's Avatar
Like the title says, what does your Torque app screen look like to monitor the vitals of your 6.0? I am not bulletproofed yet but want to be proactive and monitor everything
2005 Ford F-250 Black/Brown Lariat 4-door/shortbed
8" Fabtech Lift
20" Rims and 38" Tires
LineX Bedliner
MBRP Straight Pipe
AirRaid CAI
mad103 is offline
post #2 of 39 Old 01-06-2014, 08:00 PM
Oil Temp / Coolant Temp
Trans Fluid Temp / FICM Volts
HPOP / IPR
2 Wheelin is offline
post #3 of 39 Old 01-06-2014, 11:07 PM Thread Starter
mad103's Avatar
And what are the healthy numbers it should be reading?
8" Fabtech Lift
LineX Bedliner
MBRP Straight Pipe
AirRaid CAI
mad103 is offline
post #4 of 39 Old 01-07-2014, 06:58 AM
johnnybgood's Avatar
Quoted: 79 Post(s)
What I Monitor on my Torque App on 1 screen:
Oil Temp
Coolant Temp
Trans Temp
Intake Temp
Boost
FICM volts
Battery Volts
VGT
HPOP
Load
EBP
Oil and coolant temps should be within 15* of each other cruising on a flat highway. Mine usually hover around 185-190 warmed up which to me is healthy. Slightly higher when towing, but same 3-6* spread. Boost and VGT is there to make sure its all working properly. Hpop should be around 600 at idle, I think up close to 4K at full throttle. FICM volts @ 48 - 48.5 is healthy. Battery volts drop at startup, build up quick once running and at 13.5 - 14.1 cruising.
Here's a screen shot of mine after driving around town a bit. Added EBP and Engine Load recently.
Stiles likes this.
johnnybgood is offline
The Following User Says Thank You to johnnybgood For This Useful Post:
Stiles (03-05-2014)
post #5 of 39 Old 01-07-2014, 09:00 AM Thread Starter
mad103's Avatar
Awesome setup and thanks for the info man
8" Fabtech Lift
LineX Bedliner
MBRP Straight Pipe
AirRaid CAI
mad103 is offline
post #6 of 39 Old 01-09-2014, 10:20 PM
What setup are you using. I was and still are currently using the Scangauge 2, but I have an iPhone 4S and a Samsung Galaxy Tab 10.1. I think all I need is the "app", but what device are you using to communicate with the truck (obd2 adaptor)?
rhillman75 is offline
post #7 of 39 Old 01-10-2014, 04:25 AM
Quoted: 79 Post(s)
Ya the app and a bluetooth obdII adapter.
I went with the blue mini china ELM one for $9. Been working fine for a few months now.
Stiles likes this.
2005 Excursion Limited w/254K+ miles
-Turbo back exhaust -Harley Headlights & Grill
-OEM 20's -FICM Tuner -Torque Pro App
post #8 of 39 Old 01-10-2014, 05:39 AM
That's the one. You can get it in eBay, Amazon, or new egg.
They're pretty cheap, but work like a champ.
I've been using mine for 5 months.
Stiles likes this.
MightyMouse75 is offline
post #9 of 39 Old 02-24-2014, 02:18 PM
Mitch
thebierguy's Avatar
Quoted: 86 Post(s)
Oil Temp
Coolant Temp
Trans Temp
Intake Temp
Boost
FICM volts
Battery Volts
VGT
HPOP
Load
EBP
Is the EOT that you are using the stock "Engine Oil Temp" that comes with the App?
Mitch
2006 Ford F-350 6.0 Crew Cab Lariat Short Box./4" exhaust/SCT X4 7015 (White Noise)/Autometer Boost and Fuel Pressure(Strictly Adapter)/Edge Insight CTS2/FICM Repair.com Complete Wire Kit/08+ Rear Differential Cover/B&W Goosneck hitch/Sinister Coolant Filter/High Idle/Blue Spring/Purchased 2/28/2014
2002 Ford F-350 7.3 Crew Cab Lariat Short Box, SOLD 2/24/2014
thebierguy is offline
post #10 of 39 Old 02-26-2014, 08:56 AM
No, you have to go to settings in the first window that the app brings you to, then Manage extra PIDs/Sensors.
Once you're in there you can click the button on whichever tablet you have that allowed you to see the "settings" option.. It's usually the one that is a box with lines in it.
In that submenu you can select "Add predefined set" and then select Ford (Incl powerstroke)
That'll give you the correct PIDs that you need.
I'll try to video it later and send you the youtube.
