truck dies while driving - Ford Powerstroke Diesel Forum
post #1 of 14 Old 01-06-2014, 10:36 AM Thread Starter
MooreSix0Stroker's Avatar
Garage
Exclamation truck dies while driving
My truck stalled twice with 2 mins. Loss for all power and battery light came on. Both times I got started after about 30 sec after dying. What would cause this to happen. Outside temp is -3*, had truck running for 10 to 15 min be for leaving.
John
07 F350 cc/sb Fx4 Lariat
ARP studs, OEM
head gaskets, 4" exhaust turbo back 6" tip, egr delete, BPD oil cooler and filtration, sct turner, egde insight monitor, coolant filter, high idle mod, Recon smoked mirror and cab markers
MooreSix0Stroker is offline
post #2 of 14 Old 01-06-2014, 10:47 AM
Bluedemon6.0's Avatar
Send a message via Skype™ to Bluedemon6.0
Have the batteries load tested and alternator checked. Check and clean all your battery connections. What is your ficm voltage? A dying ficm will cause stalling or a loose battery connection.
-Steven
New!! 2015 Mustang ecoboost!!
Sold!!
formally owned:04 6L PSD CCSB
Studs
Egr delete
S&b intake
New dashboss with fuel pressure and egt
Sct Looney by Vivian and Tonywildman xtreme early lock up now
php 140x
63.5/88mm 06 turbo with a pmax billet WW2
PHP Atlas 80
My baby-
87 jeep wrangler
350 and 700r4 built by mad dawg transmission
Dyno @ 200hp and 400ftlb at 3100 rpm
On 33s
Bluedemon6.0 is offline
post #3 of 14 Old 01-06-2014, 11:03 AM Thread Starter
Garage
Ficm more likely I had floored accelerator and no power. Thank for the help
John
ARP studs, OEM
post #4 of 14 Old 01-06-2014, 11:14 AM
I would not drive until you resolve the issue check your ficm logic voltage and ficm output voltage. I would still have batteries checked and the alternator because that could have been what caused the problem to begin with.
-Steven
Sold!!
Studs
Egr delete
S&b intake
php 140x
PHP Atlas 80
My baby-
87 jeep wrangler
On 33s
post #5 of 14 Old 01-06-2014, 11:15 AM Thread Starter
Garage
If ficm is bad how much long would it last.
John
ARP studs, OEM
post #6 of 14 Old 01-06-2014, 11:25 AM
Do not drive the truck if your ficm voltage is less than 45v this could cause injector damage or so I have heard. So put a monitor on her and see what she reads. Have the batteries load tested at least to see if this the source of your problem. You can have it done for free at napa, autozone, advance, or oreilys.
-Steven
Sold!!
Studs
Egr delete
S&b intake
php 140x
PHP Atlas 80
My baby-
87 jeep wrangler
On 33s
post #7 of 14 Old 01-06-2014, 11:33 AM
twoicebergs's Avatar
Quoted: 46 Post(s)
Are you running #1 fuel or #2? If you are running #2 you probably have fuel gelling happening. It seems this is going to be an abnormally cool winter in the mid-south USA.
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
post #8 of 14 Old 01-06-2014, 11:48 AM
aka MacGyver
rick1067's Avatar
Start with the Batteries. Disconnect one Negative terminal and check both batteries with a Multi-Meter Volts DC. If either show below 11 Volts, take them to Autozone (or other auto store) and have them charge and test them. The test will show if there is an issue with that battery when it is put under a load. Also if you do not own a Battery Terminal Cleaning tool, pick one up for under $5.
Once the batteries are back in the truck and the Terminals are cleaned, start the truck and check the voltage on one battery. It should read between 12.5 - 14 Volts. If this is true it is not the batteries or alternator.
From there I would check the FICM. Follow the 4 Bolt FICM Test since your truck is an 07. Follow the proceedures in the video below.
rick1067 is offline
post #9 of 14 Old 01-06-2014, 02:14 PM Thread Starter
Garage
Tested ficm no voltage drop. Both batteries are a year old. If I had fuel gelling, what can or should I do about it?
John
ARP studs, OEM
post #10 of 14 Old 01-06-2014, 02:28 PM
Teachagmech's Avatar
Quoted: 398 Post(s)
Garage
If it's gelling, you can add a bottle of xdp or diesel kleen winter, then drive its all it's gone....
You can mix the two also. There was a guy on the what did you do to your 6.0 thread who changed his fuel filters and had to scrape out the wax cuz he had #2 and it got too cold.
Primary filter would be worth looking at
Mike"Bustin' mine to feed yours"
The "Kerosene Queen"
2005 F-250 CCSB FX4 LARIAT 150K blue spring, coolant filter, DC Power alt. and
Teachagmech is offline
