No heat below zero temps - Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By wingsandwalleyes
post #1 of 10 Old 01-06-2014, 05:24 AM Thread Starter
I know there a few threads on this nothing that matched exactly. I just did oil cooler egr delete thought that was the problem. Last really cold spell we had truck started puking coolant and heater wouldn't work. Switched out oil cooler and egr delete thought it fixed the problem temps from low of 10 and up these last few days it's been below zero and same problem I ordered a new degas bottle cap not sure if that's it or not. Any ideas
wingsandwalleyes is offline
post #2 of 10 Old 01-06-2014, 07:38 AM
Fill it up again Dummy
mhatlen's Avatar
Quoted: 552 Post(s)
Garage
Is it still blowing out coolant?
Does the heat work when rolling down the highway?
Can you see coolant moving around in coolant tank?
May be thermostat or water pump or even head gaskets. Depending on answers to above questions.
2006 F250 LARIAT CCSB 4X4
7" Icon/Carli Lift
ARP Studs, O-Ringed Heads
X4 PHP 65 HP Custom Tow Tune
Atlas40
4" SS exhaust
58K Miles on it
2000 Watts of McIntosh Bliss
mhatlen is offline
post #3 of 10 Old 01-06-2014, 09:21 AM Thread Starter
Heat works at idle it comes and goes at highway speed. I replaced the thermostat this fall. Everything works above like ten degrees.
02 7.3 likes this.
post #4 of 10 Old 01-08-2014, 05:11 AM
Bump for a similar problem.....was this fixed or does anyone have further experience?
ShaneOh is offline
post #5 of 10 Old 01-08-2014, 05:23 AM
Suck, Squish, Bang, Blow!
dfuzz78's Avatar
Sounds like the problem I had...
New head gaskets and studs fixed that problem!
Probably not the answer you were looking for...
Denis "Lt. Sled"
2006 F-350 Crew Cab Long Bed Dark Shadow Gray
462hp / 927ft-lbs Corrected
ARP Head Studs, NUC Motorsports Oil Bypass, CFM+ Intake Elbow, Wicked Wheel 2
Bullet Proof Diesel FICM w/Atlas 40, SCT SF3 w/SPD by TSD! Grover Fire Truck Horns
Cab Light Mod, Blue Spring Mod, Zoodad Mod, High Idle Mod, Lost EGR Mod
dfuzz78 is offline
post #6 of 10 Old 01-08-2014, 05:24 AM
kinnisoj's Avatar
Quoted: 2 Post(s)
Air in the system?
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #7 of 10 Old 01-08-2014, 05:26 AM
I picked up new heater core in hopes this might be the fix - another member had that work for them due to the bad OEM coolant and silicate build up . It's been single digits all this week around here and having heat for 2 minutes when the thermostat opens doesn't cut it!
ShaneOh is offline
post #8 of 10 Old 01-08-2014, 05:47 AM Thread Starter
Can anyone explain why in colder temps I get these symptoms and just below freezing it runs fine?
post #9 of 10 Old 01-08-2014, 06:01 AM
twoicebergs's Avatar
Quoted: 47 Post(s)
It could be you have weak anti-freeze and in really cold temperatures your heat exchanger or hoses are blocked. You need to check the flow through the core. You can also test temp of the hose going in and out. You could have a valve that is sticking or not working correctly on the heater core feed (assuming you have one, passenger side near the oil filler). There are other issues, but that is a good start.
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
post #10 of 10 Old 01-10-2014, 05:45 AM
AshevilleEngine.com's Avatar
Quoted: 2 Post(s)
Head gasket leak will cause combustion gases to accumulate in your heater core at idle because it's the high point in your system.
AshevilleEngine.com is offline
