2006 F250 6.0 coolant loss - Ford Powerstroke Diesel Forum
post #1 of 8 Old 01-05-2014, 06:25 PM Thread Starter
Coolant loss, no visible leakage, no white smoke, no coolant in oil, outside tempature was -3, went to town heater worked fine got to town, heater stopped working so checked coolant level and it was down, put 1 gallon anti freeze filled to min level returned home 26 miles away coolant level was not same when i got there below min level but still visible in reservoir. any ideas?
Kimber is offline
post #2 of 8 Old 01-05-2014, 06:35 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
If your not leaking it,you gotta be burning it. Head gaskets? Cracked heads?
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #3 of 8 Old 01-05-2014, 06:42 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
Up in the search box type in head gasket testing. You will find a lot of info. Their is a simple pressure test that you can do. A chemical test that will check for exhaust in the coolant.
You can also type in "using coolant"
Oh yeah and welcome to the site. Good luck.
,edge turbo timer
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #4 of 8 Old 01-05-2014, 08:30 PM
Fill it up again Dummy
mhatlen's Avatar
Quoted: 449 Post(s)
Garage
Top it off and watch level closely. Can also pull the egr valve and look into intake manifold for moisture. Most likely going to see it there first before loosing head gaskets.
But if you do see moisture in hole then: egr and oil coolers are shot.
Look into it before it becomes a head gasket issue too. What happens is if it leaks enough the coolant basically becomes a water injection system on a grand scale and raises cylinder pressure to the point where head gaskets fail.
May actually run like it has more power for a while until you loose head gaskets of coarse.
Figure it out, EGR/Oil Cooler job is under $2000.00 for sure.
Head Gaskets $5000.00 plus
2006 F250 LARIAT CCSB 4X4
ARP Studs, O-Ringed Heads
X4 PHP 65 HP Custom Tow Tune
Atlas40
CAT EC-1 Coolant, IPR Coolant filter
BPD Waterpump
Fass-125 to a Adjustable Pressure Reg.
Turbo-back SS 4" pipe, Corsa Muffler -7" Tip
6.4 starter, DC Power 270 w/ AGM regulator
Die Hard Platinum AGM all 2/0 Cables
Fabtech Radius Arms
7" lift w: Icon Progressive Coil Springs
2008 up Carli/Deaver rear springs
2000 Watts of McIntosh Bliss
All riding on some Fatty-Daddy 38/15.50/18 Toyo's
mhatlen is offline
post #5 of 8 Old 01-05-2014, 08:33 PM
Suck, Squish, Bang, Blow!
dfuzz78's Avatar
Head gaskets.
Denis "Lt. Sled"
2006 F-350 Crew Cab Long Bed Dark Shadow Gray
462hp / 927ft-lbs Corrected
ARP Head Studs, NUC Motorsports Oil Bypass, CFM+ Intake Elbow, Wicked Wheel 2
Bullet Proof Diesel FICM w/Atlas 40, SCT SF3 w/SPD by TSD! Grover Fire Truck Horns
Cab Light Mod, Blue Spring Mod, Zoodad Mod, High Idle Mod, Lost EGR Mod
dfuzz78 is offline
post #6 of 8 Old 01-06-2014, 05:48 AM
AshevilleEngine.com's Avatar
Quoted: 2 Post(s)
If there aren't any leaks, it's definitely going through the engine. it has to be EGR, cracked head or head gaskets unless it froze and cracked something internally.
AshevilleEngine.com is offline
post #7 of 8 Old 01-20-2014, 12:23 PM Thread Starter
Moisture under egr valve
I finally got a chance to let it run and then pull the egr valve. There was moisture in the bottom. Truck still runs fine do you think I need to change head gaskets also?
Kimber is offline
post #8 of 8 Old 01-21-2014, 01:25 AM
mhatlen's Avatar
Quoted: 449 Post(s)
Garage
There is a way to see if it's head gaskets or egr cooler. Look on you tube under testing for egr or head gaskets leaking.
You will need a small hose and a stopper for your coolant tank.
My guess is it's the egr cooler unless it's been leaking for a long time. Also your oil cooler is going to be plugged and need replacing and this is what causes the egr coolers to fail.
Check out YouTube on it. If your not familiar with Powerstroke engines it's best to have it done by a mechanic that is.
Atlas40
BPD Waterpump
Fabtech Radius Arms
mhatlen is offline
