Straight coolant - Ford Powerstroke Diesel Forum
post #1 of 5 Old 01-04-2014, 06:01 AM Thread Starter
Straight coolant
Working on a fleet of 6.0. guy ran straight antifreeze in four of them, been doing it for a few years. all of them that had the straight coolant are having heating problems. Will not give heat at idle on and off heat while driving. changed heater core,thermo,and water pump in one and same problem egr has been deleted in this truck. Any answers?
midnite is offline
post #2 of 5 Old 01-04-2014, 12:03 PM
Most coolants are slightly corrosive which us why most manufactuers recomenc a 50/50 mix with distilled water only.
Scale that forms gets eaten and can flake offcoating the heater core and any heatexchangers there may be.
Lord I shall lead them to the water but I will not try to make them drink
dannyboy950 is offline
post #3 of 5 Old 01-04-2014, 07:34 PM
Fill it up again Dummy
mhatlen's Avatar
Quoted: 465 Post(s)
Garage
Sure sounds like a head gasket issue to me. Testing cooling system pressure or test strips will rule out.
2006 F250 LARIAT CCSB 4X4
7" Icon/Carli Lift
ARP Studs, O-Ringed Heads
X4 PHP 65 HP Custom Tow Tune
Atlas40
2000 Watts of McIntosh Bliss
mhatlen is offline
post #4 of 5 Old 01-04-2014, 07:36 PM
ZMANN's Avatar
Quoted: 1585 Post(s)
Agreed
We Miss you Ronnie
ZMANN is online now
post #5 of 5 Old 01-04-2014, 08:06 PM
Term3's Avatar
He obviously has no clue as to boiling and freezing points of glycol. The reason there's no heat is probably because the glycol has jelled up in these cold temperatures and ain't moving thru the cooling system. Even if it was warm enough to keep it from jelling up 100% is way more thicker than water and much harder to pump around. I use a max of 70/30 glycol to water ratio to get the best cold and hot weather protection. With normal coolant temperatures glycol isn't corrosive but if it is used at 100% strength and isn't moving because its jelled up then you are creating extreme hot spots that are actually breaking down the glycol into corrosive byproducts. Localized overheating in your engine can cause warped heads.
Sent from AutoGuide.com App
SCT, no studs...yet, Dual OEM intake air filter housings, Banks intercooler & intake elbow, Banks exhaust system, Windrunner ported intake manifold, Bullet Proof Diesel remote oil cooler & thermostat, AirDog2 (plus a couple spares), Power steering filter (Amsoil dual-bypass), MagTec deep ATF pan, Electric oil pre-lub pump, Dakota Digital gauges.
Term3 is offline
