Crank no start - Ford Powerstroke Diesel Forum
post #1 of 4 Old 01-03-2014, 03:00 PM Thread Starter
Exclamation Crank no start
Workin on a 06 stock 6.0. Cranks no start. New ficm, ipr/icp sensors are functioning properly. New injectors 30k ago. Cant figure this thing out. No codes. Using auto enginuity ford bundle. Help
mcclure426 is offline
post #2 of 4 Old 01-03-2014, 04:02 PM
Check your fuel pressure.
Lord I shall lead them to the water but I will not try to make them drink
dannyboy950 is offline
post #3 of 4 Old 01-03-2014, 04:29 PM
midnite rider's Avatar
Quoted: 285 Post(s)
I agree its a common issue
-Tom
05 250 KING RANCH CCSB,278k,ARP's,SCT TSX,Atlas 40,STC done,Glowshift FP Gauge,Banks IC System,Blue Spring,Banjo's,CCV mod,Oil Bypass,Diamond Eye 5" Exhaust,Bilstein 5100's,RC Dual Steering Stabilizer,Retro 55W 6k Heads 3k Fogs,Continental Airbags,RSD 48 gal Aux Fuel Tank.
2003 F350 Lariat CCSB, 288K, Everything But Studs.
midnite rider is offline
post #4 of 4 Old 03-10-2014, 07:44 PM
I have an '07 with 124K. I have done the basic bullet proofing and have an edge programmer. I have had a similar problem, but a little different. Drive around no problem, shut off, start up, no problem. Then, randomly, I crank like crazy, no start. Volts are good. Got towed in the first time and they said I had a bad battery. Truck ran good. Then it happened again. This time I thought about it and unhooked both of my batteries, counted to 5 and hooked them back up. Truck fired up immediately. I am assuming that I have a fuel relay somewhere that is not resetting. |
Any ideas?
By the way, sorry, not trying to jack your thread. I just keep reading of similar problems and everyone is talking about all of the setting parameters and HPOPs and such, but no one has said if they unhooked batteries and made a difference.
bruce0429 is offline
