HPOP Air Test Questions - Ford Powerstroke Diesel Forum
post #1 of 2 Old 01-03-2014, 02:13 PM Thread Starter
I have a no start issue that I believe is HPO related.
I did an air test on my late 04 6.0L but I've got some questions. First of all, when I pulled the ICP to install the air plug, I noticed oil on the tip of the ICP. My question is, is it normal to have any air at all coming from the oil fill pipe on the passenger side? I don't hear any leaks, but there is a slight escape of air from the oil fill tube with the camp removed. Is this normal or is this indicative of a HPOP or other issue?
Also, I'm towing it in to have codes pulled next week. If I do have a failed HPOP or ICP, what codes should I look for?
lmorgan is offline
post #2 of 2 Old 01-03-2014, 03:59 PM
Fill it up again Dummy
mhatlen's Avatar
Quoted: 463 Post(s)
Garage
Try this first:
Unplug the ICP spray some brake clean or carb cleaner into the pigtail plug for the ICP if there is any oil in it. Let dry and then try starting it.
If you are leaking oil out of your ICP it's bad and will cause a no start issue.
No codes will be from HPOP put your ICP back in and with wiring unplugged start it up.
I hope for your sake
2006 F250 LARIAT CCSB 4X4
ARP Studs, O-Ringed Heads
X4 PHP 65 HP Custom Tow Tune
Atlas40
CAT EC-1 Coolant, IPR Coolant filter
BPD Waterpump
Fass-125 to a Adjustable Pressure Reg.
Turbo-back SS 4" pipe, Corsa Muffler -7" Tip
6.4 starter, DC Power 270 w/ AGM regulator
Die Hard Platinum AGM all 2/0 Cables
Fabtech Radius Arms
7" lift w: Icon Progressive Coil Springs
2008 up Carli/Deaver rear springs
2000 Watts of McIntosh Bliss
All riding on some Fatty-Daddy 38/15.50/18 Toyo's
mhatlen is offline
