Lots of work done, now no start - Ford Powerstroke Diesel Forum
post #1 of 3 Old 01-03-2014, 12:55 PM Thread Starter
06 6.0
So I tore it down and replaced STC fitting, stand pipes and dummy plugs, turbo oil feed and drain lines, cleaned spool valves on injectors, did and EGR cooler delete, replaced IPR valve.
So when I got it back together it wouldn't start and my Insight was only showing max of 50 psi when cranking. I tore it part way back down and did a air test and was hearing something from the passenger side. I checked the second and third back injectors and they appear to be fine.
I've gotten real frustrated with it and figured I would see if anyone else had any ideas???? Thanks
Glamping is offline
post #2 of 3 Old 01-07-2014, 02:44 PM
if you hear something you will probably have a leak. if its an injector you wont see anything. did you crank it for long enough? when doing all that work it usually takes about a minute of cranking to replace the air and build up the pressure needed to fire it up.
jeby64 is offline
post #3 of 3 Old 01-07-2014, 06:49 PM
Fill it up again Dummy
mhatlen's Avatar
Quoted: 463 Post(s)
Garage
Did you fill the HPOP with oil ???
Crank like hell to get air out of system.
Monitor gauges????
ICP
IPR
2006 F250 LARIAT CCSB 4X4
ARP Studs, O-Ringed Heads
X4 PHP 65 HP Custom Tow Tune
Atlas40
CAT EC-1 Coolant, IPR Coolant filter
BPD Waterpump
Fass-125 to a Adjustable Pressure Reg.
Turbo-back SS 4" pipe, Corsa Muffler -7" Tip
6.4 starter, DC Power 270 w/ AGM regulator
Die Hard Platinum AGM all 2/0 Cables
Fabtech Radius Arms
7" lift w: Icon Progressive Coil Springs
2008 up Carli/Deaver rear springs
2000 Watts of McIntosh Bliss
All riding on some Fatty-Daddy 38/15.50/18 Toyo's
mhatlen is offline
