03 6.0 intermittent no-starts - Ford Powerstroke Diesel Forum
post #1 of 6 Old 01-02-2014, 12:59 PM Thread Starter
Exclamation 03 6.0 intermittent no-starts
Hello everyone,
First off, I'd like to start that this is my first post but I'm a long time reader of these forums. This is such a great site, with such extensive answers that I've never needed to post my own problem. With that being said, I've encountered an issue with my 03 f250 6.0 that cannot be solved with hours upon hours of searching. This truck is stock with the exception of a bullydog gt which is ran only on the "tow" setting and a coolant filter. I have 2 codes, one is the cyl 4 glow plug circuit and the other is crankshaft position sensor. The issue I'm having is when I go to start my truck up, it is intermittently starting and when it doesnt start, it turns over for a fraction of a second and then just stops and I only can hear the starter spinning; when it does start, it seems to be turning over slow. I do have AE with the capability to monitor all values. My FICM is at 48.5v and I believe that is cranking as well. Batteries both have been charged, load tested and check out fine with 12.7 v each. IPR is at 25% and I'm having trouble remember my ICP but I believe it was 25 psi key on and 5-- something turning over. I have intermittent base oil readings which led me to pulling the oil filter housing off and observed slow oil entering. One time I did get it started, I observed the base oil (dash pressure) read normal. I have ran a buzz test and contribution test so the injectors dont seem to be the issue. I also did pull out the egr and observed a small amount of moisture which tells me the cooler is leaking and needing replacement but wouldnt cause a no start scenerio. Hopefully I was clear and concise enough. With all these things, I'm being led to 3 seperate problems. Its either the gpcm is bad, I have a leaking stc, dummy plug or icp, or the lpop has decided to bow out. I'm at a loss here and would appreciate any and all help and suggestions. It's winter here in Ohio and I'm attempting to drive a ford mustang. Thanks in advance, guys.
kyle.dias is offline
post #2 of 6 Old 01-02-2014, 07:08 PM
I think if it were me I and it was cranking slow I would look at the starter mine started to drag to the point that it wouldn't start my truck then it finally went out replaced the starter and fixed my problem. I hope it this simple for you good luck.
dj.oneil is offline
post #3 of 6 Old 01-02-2014, 09:53 PM
ps_lane01's Avatar
Quoted: 7 Post(s)
Cps cmp codes will come up with extended cranking times, i wouldnt be concerned with that.. Might want to test the glow plug system, i think AE has a self test for glow plugs. If you are cranking with ipr at .25 and icp is above 500 then that doesnt seem like a problem, if anything i would suspect a bad IPR valve. Wats icp/ipr while idling when engine is hot and when cold?
Sent from AutoGuide.com App
2003 Silver 6.0L PSD CC/SB FX4
EGR Delete, Oil Cooler upgrade
Blue Spring & Banjo Bolt Upgrade
AFE Stage II Intake, MBRP Straight 4" Turbo back
RBP 6" tip
SCT Custom Tuned
Autometer GS series
BFG A/T 285s
Recon Smoked Cab Lights
Recon Interior L.E.D.
Recon 3rd Brake L.E.D.
Custom Fiberglass Center Console
Two 10" Sundown Sa4's, Hifonics 1200 RMS mono
Optima Batteries
Meyers 7.5C Plow
ps_lane01 is offline
post #4 of 6 Old 01-03-2014, 05:21 AM Thread Starter
I agree that the cps code is probably due to extended crank times, but I was getting that code way before I ran into the no start issue. The other reason I bring the cps up is because the crank times are not that long. When I go to start it, it will turn over for a fraction of a second and stop like it's hydrolocked and all I can hear is the starter spinning and the dashboard oil pressure gauge doesn't move. When the truck does start, the dash oil pressure rises as normal and then doesn't have an issue starting other than it sounds slower than normal. Recapping that, I forgot to mention I have had the hpop, icp, ipr replaced almost 2 years ago ( not saying thats not the issue).
As for the reading while idling, I cannot be certain at this moment but I'm pretty sure the ficm was 48.5, icp 750 ish and ipr 28%. I apologize I don't have exact readings, while I was attempting to open up my fuel filter housing, the frail plastic snapped and now I cant attempt to start because it sprays diesel everywhere, especially in my eyes ha.
I did try to run the glow plug test with AE and it said it failed/ truck wasn't in the right state so that is probably the module needing replacement. But, would that cause a no start?
post #5 of 6 Old 01-03-2014, 06:01 PM Thread Starter
any other ideas as to why it would only crank for a second and stop?
post #6 of 6 Old 01-09-2014, 12:51 PM Thread Starter
Just a bump looking for other suggestions.
Tags
glow plugs , icp , no dash oil pressure , no start
