No Start Hot - Ford Powerstroke Diesel Forum
post #1 of 14 Old 01-01-2014, 06:31 PM Thread Starter
No Start Hot
Guys, bare with me. I know there's tons of info here and other places. I have what I think is a unique issue (doesn't everyone). Here goes...
Here's the run down:
Truck had long crank cold
Truck would not start cold (luckily in driveway)
Replaced: stand pipes, d-plugs, STC fitting, FICM
Installed IPR GENII EGR delete and up pipe.
Reconditioned turbo.
Cleaned egr and reinstalled.
All new filters and Rotela T6
Truck started and ran for a week during very cold weather.
Now truck will not start when hot.
Conducted HPOP system air leak test with adapter thru ICP port. No leaks detected.
Installed known good IPR. No change. Will not start hot.
Going thru this list just made me realize I had not conducted air test after engine was warm!!! If I have a no start after truck heats up, probably should test under that condition! Duh...
Longer thread posted here: http://www.ford-trucks.com/forums/12...sues-help.html
Thoughts?
lazyadt is offline
post #2 of 14 Old 01-01-2014, 07:41 PM
Fill it up again Dummy
mhatlen's Avatar
Quoted: 449 Post(s)
Garage
What are your:
ICP values at hot crank
IPR values at hot crank
FICM voltages
Fuel pressure
Battery voltage at crank
RPM
2006 F250 LARIAT CCSB 4X4
ARP Studs, O-Ringed Heads
X4 PHP 65 HP Custom Tow Tune
Atlas40
CAT EC-1 Coolant, IPR Coolant filter
BPD Waterpump
Fass-125 to a Adjustable Pressure Reg.
Turbo-back SS 4" pipe, Corsa Muffler -7" Tip
6.4 starter, DC Power 270 w/ AGM regulator
Die Hard Platinum AGM all 2/0 Cables
Fabtech Radius Arms
7" lift w: Icon Progressive Coil Springs
2008 up Carli/Deaver rear springs
2000 Watts of McIntosh Bliss
All riding on some Fatty-Daddy 38/15.50/18 Toyo's
mhatlen is offline
post #3 of 14 Old 01-01-2014, 09:57 PM Thread Starter
Originally Posted by mhatlen View Post
What are your:
ICP values at hot crank - 2.6mPa
IPR values at hot crank - 84%
FICM voltages - 48V
Fuel pressure - unknown
Battery voltage at crank - 12.6V
RPM
If there's anything else, just let me know.
lazyadt is offline
post #4 of 14 Old 01-03-2014, 09:27 AM Thread Starter
Anyone? Bump. I have made an acquaintance at the local Ford dealership with a master tech. He is going to assist in some diagnostics this evening.
lazyadt is offline
post #5 of 14 Old 01-03-2014, 10:03 AM
mhatlen's Avatar
Quoted: 449 Post(s)
Garage
The ICP figure i don't understand. Can you get that in psi ?
But the IPR value is crazy high. It is closing up trying to build pressure. Did it hit that figure at beginning of crank or was it a long crank time ?
Try to get the ICP #'s but what the truck does need to start is a minimum of 500 psi. The FICM turns on power for injectors at that pressure.
Atlas40
BPD Waterpump
Fabtech Radius Arms
mhatlen is offline
post #6 of 14 Old 01-03-2014, 10:09 AM Thread Starter
That's roughly 300psi. I have unplugged the ICP in order to default PCM with no change. Yes, IPR # with long crank.
lazyadt is offline
post #7 of 14 Old 01-03-2014, 10:53 AM
mhatlen's Avatar
Quoted: 449 Post(s)
Garage
That's a problem fore sure. Like I said until the HPO system hits 500psi the injectors won't come on.
What I would look at first is your IPR. Pull it and inspect screen for damage and spool for any foreign material.
Atlas40
BPD Waterpump
Fabtech Radius Arms
mhatlen is offline
post #8 of 14 Old 01-03-2014, 10:58 AM Thread Starter
Had it out three time and installed a known good one on the last. Never had any damage or debris on the screen. Worked instantly when performing air test.
lazyadt is offline
post #9 of 14 Old 01-03-2014, 11:32 AM
mhatlen's Avatar
Quoted: 449 Post(s)
Garage
What year is truck?
Did you hear any leak on air test. You most likely have a leak or bad HPOP.
Atlas40
BPD Waterpump
Fabtech Radius Arms
mhatlen is offline
post #10 of 14 Old 01-04-2014, 11:07 AM Thread Starter
2005 lariat. No sound in air test. Had master tech confirm while engine was warm. As he was explaining the HPOP and STC, he mentioned the orings below the pump. I can't recall installing them... If I didn't, once the oil gets warm, the lpop builds enough pressure to blow the oil out the HPOP inlet. My understanding of the HPOP is it's a pressure pump only and will not suck. Does this sound logical?
lazyadt is offline
