Replaced LPOP gears now NO OIL to the oil filter canister. - Ford Powerstroke Diesel Forum
post #1 of 8 Old 12-31-2013, 01:03 AM Thread Starter
(SOLVED) Replaced LPOP gears now NO OIL to the oil filter canister.
(SOLVED: read below)
Before: Crank No Start. No reading on the dash oil gauge. So with oil filter removed and oil filer drain plunger closed it would crank for 17 sec before oil would enter the canister. Took 10 additional seconds to fill. 27 seconds total. Still no start.
Now: Changed out the lpop gears, front cover, and seal / wear ring. I also replaced the oil cooler, STC, standpipes, dummy plugs, and a bunch of HPOP & fuel regulator gaskets and o-rings. I get NO oil in the oil filter canister.
Findings: Even tho I installed new updated OEM parts, every old part looked good, heck looked great. Except for the oil cooler reservoir screen was torn. The lpop gears had some scoring from signs of small debri and the front cover was gouged. I removed the lpop gears and oil pressure regulator, and cleaned that housing area very well, to ensure no debri was in there.
Problem: no oil to the oil filter canister as all. Could I have installed the oem lpop gears in backwards. (Does that matter?) Could I have installed the oil pressure regulator improperly. I put the spring inside of the metal sleeve then screwed it in the block. Looked correct to me.
I'm sure it is something simple. Fingers crossed.
Thanks in advance.
Drive it like you stole it, Or I will.
**ATTENTION SCREEN HOGS
If your signature block picture is bigger than most peoples post, maybe it's time to fix it. I suggest you tape a photo of your truck to your computer screen, then it only screws up your view.
gary6.0 is offline
post #2 of 8 Old 12-31-2013, 06:04 AM
I have always worked of off the assumption that they ship them preassembled for a reason
so I do my best not to mess with orientation.
With as many parts as you have changed it is hard to guess where an error may have occured.
Lord I shall lead them to the water but I will not try to make them drink
dannyboy950 is offline
post #3 of 8 Old 12-31-2013, 06:39 AM
HP MACHINE's Avatar
Quoted: 165 Post(s)
Get a look at the IPR screen , I'm just going thru a similar scenario . Ours had came apart
and lodged some plastic under the plunger . Carefully removed the pieces and cleaned.
Not sure if it's related , but a thought .
Hope you get it sorted !
HP MACHINE is offline
post #4 of 8 Old 12-31-2013, 10:29 AM Thread Starter
Thank you for the reply guys. I am hoping the problem is in the lower pump area because I can not see how the top end would be the cause.
I did install the both the inner and outer gear the same as it came out of the package. But i know some aftermarket gears have stamping, marks, or beveled edges to orientate which side faces the front cover. The OEM looked the same on both sides. Hoping someone can chime in on this.
Also the IPR screen is new. But i could understand how it could cause a no start.
I am still hoping the problem is with how I installed the oil regulator spring. I think I put it in the same way it came out. pretty straight forward... but you know. this is a 6.0. lol
gary6.0 is offline
post #5 of 8 Old 12-31-2013, 03:26 PM
x148's Avatar
I worked on a 6.0 not long ago with a similar issue, new lpop due to oil filter housing not filling up. After new gears the filter housing would not fill up, we tried a bunch of things since we have several spare motors. We ended up putting in a two gallons of lucas oil because its real thick an sure enough the truck ran great. Turns out the bearings are so worn due to the fact truck has 300k and the oil clearances were too big to push the oil up to the HPOP
05 F350
-Sinister EGR Delete
-Banks High Ram
-Blue Spring
-Air Dog II
-K&N Intake
-H&S Mini Max
-Swamps 58v FICM
-03 Turbo
-5" MBRP turbo back
-ARP Head Studs
-Cat ELC1 Coolant
-6" Lift on 37" Toyo M/T
-Detriot True-Trac with 4.56 Gears
-Pro Comp Trac Bars
x148 is offline
post #6 of 8 Old 12-31-2013, 09:16 PM Thread Starter
Happy New Years folks.
Ok that sounds odd to have to add 2 gallons of thick Lucas oil but that just might do the trick. This engine has 172k miles. BEFORE, It did fill the oil canister in less than 10 sec after 17 sec of cranking.
The oil path is from the pan to the pickup tube to the lpop to the oil filter canister??, then to the oil cooler. correct?
gary6.0 is offline
post #7 of 8 Old 01-01-2014, 07:01 AM
Powerstroke Techie
Quoted: 17 Post(s)
Garage
Feedback Score: 4 reviews
The gear orientation doesn't matter. I do make sure to leave the 2 pieces in the way they came out of the packaging but there are no markings to indicate which way they go into the front cover.
An old trick is to pack the gears with petroleum jelly to aid in creating suction before the system is primed. I have never put a set of gears back in without doing this and thankfully I've never had a problem.
The oil pressure regulator only goes in one way. The cap goes in flat side first, the spring goes in next fitting into the recess in the cap, then the plug screws in last to hold it all in.
-Matt
Ford Senior Master Tech
2015 F-250 XLT 6.7L
2006 F-250 6.0L SOLD
sinner6.0L is offline
post #8 of 8 Old 01-01-2014, 01:28 PM Thread Starter
SOLVED! Sinner6.0L thanks for the petroleum jelly trick.
I removed the balancer and the front cover. The seal still looked new. That's good. The inside of the front cover still looked new. Thank goodness, I was afraid it had possible been the problem. Not a drop of oil tho. Hmm. Same with the gears. Still clean. So I pulled out the otter gear with a magnet and stuffed the gears with petroleum jelly. Reinstalled the front cover and cranked it over using the factory starter jumper cable on the passenger side. Removed the oil filter. Depressed the drain valve and cranked the engine. Sure enough... It filled with oil in seconds!!!!
I put everything back together and got ready to fire it up. Still not firing but at lease now my ICP% is up.
Thank you all for your input and help. One more problem solved, one step closer to getting it running.
gary6.0 is offline
Tags
lpop , oil
