No black smoke!?! - Ford Powerstroke Diesel Forum
post #1 of 9 Old 12-30-2013, 04:08 PM Thread Starter
No black smoke!?!
My truck had been blowing a bit of black smoke with my bully dog 50hp programmer but recently I have lost a little bit of power and the black smoke.
I imagine I have a fuel related issue. The truck has been good to me, 113k. Over the last couple winters I have developed some injector stickton issues when below 35 degrees or so. Other than that no problems.
I'm not quite due for fuel filters but I'm going to do it to rule out clogged filters. I'm pretty religious about draining out the separator and I've notice a touch of leaking fuel possibly leaking from somewhere down there.
And I have replaced the fuel pressure regulating assembly on the secondary filter.
I've searched the forums and got somewhat of a plan on looking for the problem. What I don't have is the scan tools and gauges to really look at much of anything.
I plan on replacing fuel filters, looking for the leak, disconnecting battery to reset comp, then ???..........what easy stuff can I look at before taking it to the shop? Thanks!
Apcerame is offline
post #2 of 9 Old 12-30-2013, 05:13 PM
Powerstroke Techie
Lilpooh's Avatar
Feedback Score: 3 reviews
Not only possible fuel delivery issue, but a weak HPOP system can cause lack of power and no "black smoke".
Sent from AutoGuide.com App
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
post #3 of 9 Old 12-30-2013, 05:30 PM
C_Healy0360's Avatar
Check your ficm voltage
C_Healy0360 is offline
post #4 of 9 Old 12-31-2013, 04:15 AM Thread Starter
Makes sense. I hope not I've already had everything replaced because I had a leaking sct fitting about 15k ago. I think I already know the answer but, Is there anyway to check the hpop without a scan tool?
Apcerame is offline
post #5 of 9 Old 01-01-2014, 03:43 PM Thread Starter
Well, decided to return my tune to stock, remove the tuner. The truck felt very weak. Almost to the point where I had trouble pulling out in traffic. Disconnected the battery, let it sit about 2 mins, reconnected and it ran a bit better. Reinstalled the tuner and the truck ran at 100%.
So, will this last? I remember reading a thread about someone with the same problems and they came back. Why would my truck's tune get hosed up? Hopefully I didn't damage the injectors or anything. I'm certainly going to invest in some gauges to monitor my fuel pressure, hoop pressure, etc.
Apcerame is offline
post #6 of 9 Old 01-01-2014, 03:54 PM
Bluedemon6.0's Avatar
Send a message via Skype™ to Bluedemon6.0
Stuck egr valve, ficm, or a clogged map sensor would be my guess. If you have a egr valve remove and clean then remove the map hose and use a allen wrench to clear the intake side and map sensor side then just blow the tube clean. If all is good check ficm voltage using a multimeter. Here is a link. http://www.ficmfixer.com/testing.htm
-Steven
New!! 2015 Mustang ecoboost!!
Sold!!
formally owned:04 6L PSD CCSB
Studs
Egr delete
S&b intake
New dashboss with fuel pressure and egt
Sct Looney by Vivian and Tonywildman xtreme early lock up now
php 140x
63.5/88mm 06 turbo with a pmax billet WW2
PHP Atlas 80
My baby-
87 jeep wrangler
350 and 700r4 built by mad dawg transmission
Dyno @ 200hp and 400ftlb at 3100 rpm
On 33s
Bluedemon6.0 is offline
post #7 of 9 Old 01-01-2014, 07:23 PM
Fill it up again Dummy
mhatlen's Avatar
Quoted: 449 Post(s)
Garage
For crying out loud go get yourself a ScanGaugeII. They are only 150.00 and can save you thousands by knowing whether or not your oil cooler is going to trash your engine.
Anyone who does not run a monitor in a 6.0 is foolish and I mean that harshly.
Auto Zone has them on the shelf.
2006 F250 LARIAT CCSB 4X4
ARP Studs, O-Ringed Heads
X4 PHP 65 HP Custom Tow Tune
Atlas40
CAT EC-1 Coolant, IPR Coolant filter
BPD Waterpump
Fass-125 to a Adjustable Pressure Reg.
Turbo-back SS 4" pipe, Corsa Muffler -7" Tip
6.4 starter, DC Power 270 w/ AGM regulator
Die Hard Platinum AGM all 2/0 Cables
Fabtech Radius Arms
7" lift w: Icon Progressive Coil Springs
2008 up Carli/Deaver rear springs
2000 Watts of McIntosh Bliss
All riding on some Fatty-Daddy 38/15.50/18 Toyo's
mhatlen is offline
post #8 of 9 Old 01-02-2014, 04:49 AM Thread Starter
I'm thinking on spending the money and going with the edge insight cts. I plan on keeping the truck for awhile so I need to get on monitoring my truck
Apcerame is offline
post #9 of 9 Old 01-04-2014, 04:57 AM Thread Starter
Picked up an edge insight cts and the expandable egt probe yesterday. I hooked up the monitor last night.
Took a 85 mile trip and watched my ficm voltage for awhile. I had ficm problems in the past and pulled it out to replace the lead free solder with the good stuff so I was curious to see what the voltage was. At startup it dropped to 45V and came back up and hovered around 47.5 to 48.5 for the most part. A few times accelerating my wife saw it drop to 44.5.
When my sct fitting failed (left me stranded) I had all the updated parts and a coolant flush(still running ford stuff) put in so I took a look at my delta. I know 15 is the highest, I saw about 8 on average with it not going over 10.
The insight was a good investment and I wished I would of put the money into it earlier. I almost want to say I'm looking forward to another 6.0 hiccup.
Bullydog CAI
Bullydog 50 hp tuner(looking forward to upgrade to SCT)
Edge Insight CTS + EGT probe
Fast idle mod
Updated blue spring
Resoldered FICM
Leveling kit w/ 35" MT ATZs
Kenwood dbl din w/ Garmin gps, mtx preformed sub, inf door spkrs
Apcerame is offline
