Is it in yet? - Ford Powerstroke Diesel Forum
post #1 of 4 Old 12-30-2013, 03:53 PM Thread Starter
Is it in yet?
I am reassembling and slid the egr cooler hose back onto the oil cooler, but I am not sure it is on all the way. I can not seem to get it on any further. I tried to turn it and push further but no luck. Do you think it is on there enough? I really do not want to have to re-attend to it later. There was a mark in the egr cooler pipe, I assume it means "push to here" but I can not see it yet.
Thanks Brian
ID:	220130   Click image for larger version
ID:	220138   Click image for larger version
ID:	220146   Click image for larger version
Whoisjohngalt is offline
post #2 of 4 Old 01-01-2014, 02:38 PM
it seems to me that it there was marks on my hose 1 line was unlock and 2 lines was locked. I put mine on and locked it then pulled on it and so far a year latter no problems. good luck
dj.oneil is offline
post #3 of 4 Old 01-01-2014, 02:53 PM
Fill it up again Dummy
mhatlen's Avatar
Quoted: 448 Post(s)
Garage
Looks ok to me.
Like title lol
2006 F250 LARIAT CCSB 4X4
ARP Studs, O-Ringed Heads
X4 PHP 65 HP Custom Tow Tune
Atlas40
CAT EC-1 Coolant, IPR Coolant filter
BPD Waterpump
Fass-125 to a Adjustable Pressure Reg.
Turbo-back SS 4" pipe, Corsa Muffler -7" Tip
6.4 starter, DC Power 270 w/ AGM regulator
Die Hard Platinum AGM all 2/0 Cables
Fabtech Radius Arms
7" lift w: Icon Progressive Coil Springs
2008 up Carli/Deaver rear springs
2000 Watts of McIntosh Bliss
All riding on some Fatty-Daddy 38/15.50/18 Toyo's
mhatlen is offline
post #4 of 4 Old 01-02-2014, 12:07 PM Thread Starter
Thanks guys .... it wasn't. I had seen others on this site with the numbers on them to align it correctly for install, .... mine ... aftermarket did no have any markings on it. I removed the barb fitting that accepts it from the top of the oil cooler (just two bolts and I was able to slide it back off of the egr cooler) and it just popped right off in my hand. I knew it was supposed to "click" when it went on, ....it didn't. On the bench, I was able to really look at it and see how it was supposed to be rotated and pressed to the "snap". I was able to then slide it back on the egr cooler and bolt it back on. All is well now, I am glad I took the time, ...it just did not look right (whata mess that woulda been).
