6.0 low ficm voltage on startup - Ford Powerstroke Diesel Forum
post #1 of 2 Old 12-30-2013, 09:46 AM Thread Starter
Hey guys i have an 06 f450 dump in the shop that is verrry hard starting when cold. it wants to kick every couple times the motor comes around, puffs black smoke and then dies right out. I finally got it running, got it in the shop and checked everything out with ids. my ficm input voltage is good, output to start was like 25v and then started to climb after a little bit to around 32-35v. i went for a ride with it to get it up to operating temp for maybe 2-3 miles. still reading low 30s for voltage output. I parked it with it still running and voltage climbed to 47-49. Is the ficm itself causing the lazy voltage increase or could something elsE? I shut the truck down for a while, restarted it and the voltage was in the mid 30s again. What gives???
mammarellom is offline
post #2 of 2 Old 12-30-2013, 10:13 AM
Mod Newbie
dhanna6powerstroke's Avatar
Quoted: 20 Post(s)
FICM power supply is junk. Also need to load test each battery independently and make sure the charging system is in good shape.
dhanna6powerstroke is offline
