6.0 l wont start icp,ipr,ficm, all test good. - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 26 Old 12-29-2013, 06:55 PM Thread Starter
hey guys i just bout a 2005 f250 and it will not start, i have scan gauge 2 connected to it and while cranking engine the ICP is 1100-1400psi, IPR% is 35-50, FICM test good have 4 prong FICM tested with volt meter on prong closest to driver side and had 48 Volts during injector clatter and while cranking and scan gauge says 47-48 V while cranking. FICM is syncing also. So no hpop issue or icp issue. did find the MAT(manifold air temp.) on the scan gauge reading -40 when unpluged sensor it went to 419, thought mabey it should be close to ambient temp. when engine hasent ran for a long while. could this be my problem for not cranking? while engine is spinning over little whitish gray smoke is coming out of tailpipe. any ideas? thanks.also forgot to mention upgraded to the blue spring update kit for fuel pressure regulator yesterday, pulled check valves on heads where fuel enters heads no debris found, pulled ficm, fuel pump, and pcm fuse and cranked engine over no bubbles in fuel filter resevoir. checked and replaced both primary and secondary filters. seems to be plenty of fuel pressure at front of heads. any advice would be greatly appreciated.
poorboyz is offline
post #2 of 26 Old 12-29-2013, 07:54 PM
twoicebergs's Avatar
Quoted: 46 Post(s)
It sounds like you have all the ingredients to start, so what is the problem? My questions are:
- How cold is it where your truck is sitting?
- Do your glow-plugs work?
- Is your fuel good with no water?
- What was the condition of the truck when it was last run?
- Is it cranking fast enough for a start?
Since it has sat, it is possible you have stiction issues to 2 or more injectors and that would make it a bear to start.
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
post #3 of 26 Old 12-30-2013, 05:10 AM
Powerstroke Techie
Lilpooh's Avatar
Feedback Score: 3 reviews
A shorted out EBP sensor will cause a no start, so will GPM issues.
Sent from AutoGuide.com App
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
post #4 of 26 Old 12-30-2013, 08:18 PM Thread Starter
ok friend came over with snap on motis, p0264 injector circut low on cyl 2, p0268 injector circut high on cyl 3, p0270 injector circut low on cyl 4, my question is do i have open and shorted injector coils since circut voltage is low and high on multiple injectors? batt voltage is good and load tested batteries. or do i have a bad FICM? can a FICM be bad with 48 volts showing on my scan gauge and with volt meter as in the ficm test? i read in another forum somewere it can still be bad ficm and still show 48 v. on test. i remove the ficm 2nite and dissasembled smelt burnt but did not see any obvious burnt spots. you can get a ficm rebuild kit not the logic side but the 48 volt side. But is it bad even though i read 48 v? could it not be sending 48v to the three injectors that are giving codes?
poorboyz is offline
post #5 of 26 Old 12-30-2013, 08:26 PM Thread Starter
approx 50 deg. F, no water in fuel. man i bought it from said it lost throttle response when on highway going 60-70 and wouldnt rev up in drive. put it in park and it would rev up. pretty much idled it home like it was in limp mode. got it home and cut it off. it would crank up when warm but next morning it wouldnt. he said he cranked it with a little help from propane then when it was running on the gas he turned the gas off. after it warmed up it would crank again. im not going to do that and blow my heads off when the glow plugs come on, dont like using either neither. but have had this problem sense then.
poorboyz is offline
post #6 of 26 Old 01-18-2014, 02:29 PM
no-tel-in's Avatar
Bump!
I have a truck with very similar conditions.. Any outcome here?
2000 F-250 4x4 7.3
BTS Transmission - 6.0L Cooler
GTP38r
Full Fuel System with Return
2-Stage W/M & Nitrous
Adrenaline HPOP
238/100's
no-tel-in is offline
post #7 of 26 Old 01-18-2014, 04:21 PM Thread Starter
yea my truck is running now replaced no. 2-3-4&6 injectors. runs fine now when engine is hot. i still have a stiction problem now with the ones i did not replace when engine is cold or on a cold start but ten min. later it runs great. when i get a little extra money i will replace the other 4 and problems will be solved. hope this helps.
poorboyz is offline
post #8 of 26 Old 01-18-2014, 07:44 PM
Huge Mythical Beast!!
LoxDiesel's Avatar
Quoted: 350 Post(s)
Sounds like someone ran the truck out of fuel a few times too many. Thats what kills injectors
@loxdce
LoxDiesel is offline
post #9 of 26 Old 01-19-2014, 07:56 AM
This could be a wireing issue also. It doesn't matter if you have the best FICM in the world if the signal doesn't get to the injectors.
Lord I shall lead them to the water but I will not try to make them drink
dannyboy950 is offline
post #10 of 26 Old 02-13-2016, 06:20 PM
king_of_ctown's Avatar
Quoted: 2 Post(s)
Reviving this thread. I NEED HELP!!!! I have just completed a big job including new HPOP, IPR, ICP, ICP pigtail, sinister egr delete, bulletproof diesel oil cooler system, bulletproof water pump, FICM, glow plugs, batteries, mishimoto thermostat and sinister bypass coolant system. I decided to do all this after the truck died running 60mph down the road. No surge, no stutter, just died. After putting it on the computer and not getting anything I took it to ford. $318 later they diagnosed a failed HPOP. I opted to go ahead and do everything while I was in there. Lo and behold, get it all back together...... Nothing. Doing the same exact thing. Will crank but won't fire. Motor is a 2005. HELP!!!!! The pic shows my scan gauge II while cranking.
king_of_ctown is offline
