Oil leak!! - Ford Powerstroke Diesel Forum
post #1 of 3 Old 12-28-2013, 08:04 PM Thread Starter
Oil leak!!
Well when I start my truck to let it warm it, it leaks oil. Clean oil. It's cleaner then what is on the dipstick. But after I drive it it doesn't leak as bad or at all.
During idle/warm up it is like a drop every 3-4 sec.
When it's warm it doesn't leak anywhere near that amount
Oil leaks when I keep it plugged in
It is running down the back of the motor near the starter and the block heater
I pulled off a few parts on top and couldn't see anything really
Some oil in turbo piping going to the intercooler and a few drops in the tubing from air intake to the turbo but I understand that's due to the ccv
Any ideas? I have an egr delete in the mail and I'm hoping to find out more about this leak when I get then intake manifold off and lots of cleaning part.
Could it be a gasket on the oil cooler? Or the hpop?
Any tips or tricks or things to look for would be awesome
R1-like is offline
post #2 of 3 Old 02-20-2014, 05:48 AM
Noticed this was a bit of an older post. Was curious if you found anything out?
06sduty is offline
post #3 of 3 Old 02-20-2014, 08:06 AM Thread Starter
Haven't really seen anything since I did the egr delete
R1-like is offline
