Coolant Leak...is this yet another Head Gasket? - Ford Powerstroke Diesel Forum
post #1 of 8 Old 12-28-2013, 06:49 PM Thread Starter
Hivolts's Avatar
I have a coolant leak, rear right side of the engine which looks to be around the head gasket. It drips on the starter. Is the only thing this could be is a head gasket leak? I have OEM gaskets with ARP studs that have less than 3000 miles. could I just try and tighten the head bolt in the back? This is my 4th set and the truck doesn't have 80,000 miles yet.
HIVOLTS
2006 F350 Crew Cab Short Bed, 6 spd Manual, Rebuilt, bored 30 over and Colt Stage II Cam, Warren Inj, Custom Fuel System, Airdog, Powermax with wheel, Icon 4" lift and some other random things thrown in the mix.
Hivolts is offline
post #2 of 8 Old 12-28-2013, 07:01 PM
ZMANN's Avatar
Quoted: 1564 Post(s)
your pic is too small for Me but
i would look long and hard for the leak even pressurize the system
blown head gaskets aren't known to leak externally as a rule but you may be the exception
We Miss you Ronnie
ZMANN is offline
post #3 of 8 Old 12-28-2013, 07:16 PM Thread Starter
Hivolts's Avatar
Thanks. I unfortunately always seem to be the exception. But now I have some hope. I tried adding a larger picture...but it's still not the best.
HIVOLTS
Hivolts is offline
post #4 of 8 Old 12-28-2013, 07:35 PM
ZMANN's Avatar
I had a leak I chased for a while
I also thought it was a head gasket till I talked to some pro's at Strictly
eventually i found it using a dry paper towel
mine would only leak when cool and not under pressure mine was a loose clamp at the heater bypass valve were I had my coolant filter tee'd in
good luck !
We Miss you Ronnie
ZMANN is offline
post #5 of 8 Old 12-28-2013, 07:48 PM
Bluedemon6.0's Avatar
Send a message via Skype™ to Bluedemon6.0
I'm no pro but if it were me I would check the small blue tube going to the oil cooler most likely it is that or the heater control valve inline with the heater core. Like Zmann said not likely a blown hg leaks externally. It is coming from the top of your motor, I had a similar leak it was the blue tube going to the egr delete to the oil cooler. You just got to put your hand in the valley on top of the motor and you will find it. Good luck!
-Steven
New!! 2015 Mustang ecoboost!!
Sold!!
formally owned:04 6L PSD CCSB
Studs
Egr delete
S&b intake
New dashboss with fuel pressure and egt
Sct Looney by Vivian and Tonywildman xtreme early lock up now
php 140x
63.5/88mm 06 turbo with a pmax billet WW2
PHP Atlas 80
My baby-
87 jeep wrangler
350 and 700r4 built by mad dawg transmission
Dyno @ 200hp and 400ftlb at 3100 rpm
On 33s
Bluedemon6.0 is offline
post #6 of 8 Old 12-28-2013, 09:10 PM
twoicebergs's Avatar
Quoted: 46 Post(s)
It is probably from a hose leak in the valley.
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
post #7 of 8 Old 12-28-2013, 09:43 PM
Jack Lester's Avatar
Quoted: 3 Post(s)
Have you figured out why you keep blowing gaskets or is it still a mystery? What work has been done when replacing them??
Jack Lester is offline
post #8 of 8 Old 12-28-2013, 09:53 PM
My valley is covered in goo and grime. Imma get at it in the morning and see if I can find any lose connections or bolts. I have a little oil leak
R1-like is offline
