no start. giving up - Ford Powerstroke Diesel Forum
post #1 of 20 Old 12-28-2013, 01:38 PM Thread Starter
no start. giving up
I have a 05 that i just finished doing studs, gaskets, hpop, icp, ipr, stand pipes, dummy plugs the whole nine yards. I started this all with a no start so figured while I was in there im only doing it once. Found dummy plugs to have the oring almost completely gone. Finished the studs now it still has a ling crank any help please? Should i be looking into low pressure side of oil system? thanks
mdlktm70 is offline
post #2 of 20 Old 12-28-2013, 01:49 PM
Fill it up again Dummy
mhatlen's Avatar
Quoted: 463 Post(s)
Garage
Did you fill the hpop reservoir before closing it up?
2006 F250 LARIAT CCSB 4X4
7" Icon/Carli Lift
ARP Studs, O-Ringed Heads
X4 PHP 65 HP Custom Tow Tune
Atlas40
2000 Watts of McIntosh Bliss
mhatlen is offline
post #3 of 20 Old 12-28-2013, 07:08 PM Thread Starter
Yes I did made sure it was completely full along with filter housing
mdlktm70 is offline
post #4 of 20 Old 12-28-2013, 07:17 PM
Bluedemon6.0's Avatar
Send a message via Skype™ to Bluedemon6.0
How long are you turning the key? Do you have a monitor that can read icp? Get you a battery charger and hook it up to one of the batteries, then turn the key for at least 15 seconds then wait a minute and repeat until she fires. If you did everything you said you did then the truck has to build pressure like 500 icp before the injectors will fire.
-Steven
New!! 2015 Mustang ecoboost!!
Sold!!
formally owned:04 6L PSD CCSB
Studs
Egr delete
S&b intake
New dashboss with fuel pressure and egt
Sct Looney by Vivian and Tonywildman xtreme early lock up now
php 140x
63.5/88mm 06 turbo with a pmax billet WW2
PHP Atlas 80
My baby-
87 jeep wrangler
350 and 700r4 built by mad dawg transmission
Dyno @ 200hp and 400ftlb at 3100 rpm
On 33s
Bluedemon6.0 is offline
post #5 of 20 Old 12-29-2013, 10:00 AM
Do you get her fired up yet? Keep us posted. Maybe you can find a local member in mass. to help you out. Idk if you have checked out the stickies under the 6.0 discussion but if not there is good info on how to monitor and a no start thread.
-Steven
Sold!!
Studs
Egr delete
S&b intake
php 140x
PHP Atlas 80
My baby-
87 jeep wrangler
On 33s
post #6 of 20 Old 12-29-2013, 01:56 PM Thread Starter
I get it to fire after about 5-10 seconds runs fine once fired up just irritating that's the whole reason I pulled it apart in the first place. It has between 25-50 icp pressure for the first few seconds then jumps right up to 550 and fires right up. Almost like there's air or something in the system
mdlktm70 is offline
post #7 of 20 Old 12-29-2013, 04:02 PM
twoicebergs's Avatar
Quoted: 46 Post(s)
How long have you run it since your fix? Assuming you have no other installation error, it sounds like your new IPR may be sticking. You wouldn't be the first one to have some dirt or contamination cause IPR issues.
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
post #8 of 20 Old 12-29-2013, 04:11 PM
x148's Avatar
Where are you located in mass
05 F350
-Sinister EGR Delete
-Banks High Ram
-Blue Spring
-Air Dog II
-K&N Intake
-H&S Mini Max
-Swamps 58v FICM
-03 Turbo
-5" MBRP turbo back
-ARP Head Studs
-Cat ELC1 Coolant
-6" Lift on 37" Toyo M/T
-Detriot True-Trac with 4.56 Gears
-Pro Comp Trac Bars
x148 is offline
post #9 of 20 Old 12-29-2013, 05:22 PM Thread Starter
In bellingham
mdlktm70 is offline
post #10 of 20 Old 12-29-2013, 06:35 PM
hey guys i just bout a 2005 f250 and it will not start, i have scan gauge 2 connected to it and while cranking engine the ICP is 1100-1400psi, IPR% is 35-50, FICM test good have 4 prong FICM tested with volt meter on prong closest to driver side and had 48 Volts during injector clatter and while cranking and scan gauge says 47-48 V while cranking. FICM is syncing also. So no hpop issue or icp issue. did find the MAT(manifold air temp.) on the scan gauge reading -40 when unpluged sensor it went to 419, thought mabey it should be close to ambient temp. when engine hasent ran for a long while. could this be my problem for not cranking? while engine is spinning over little whitish gray smoke is coming out of tailpipe. any ideas? thanks.
poorboyz is offline
