03 only starts when cold!! - Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By damuddog
post #1 of 8 Old 12-28-2013, 12:35 PM Thread Starter
I have a 2003 6.0 with 105k on it. My truck will only start when it is cold. It runs great once it starts as well as starts up with a little bit of starting fluid. Any ideas on what this can be?
tkeith87 is offline
post #2 of 8 Old 12-28-2013, 05:09 PM
Fill it up again Dummy
mhatlen's Avatar
Quoted: 449 Post(s)
Garage
Hpo oil leak for sure. Could be injector I rings to dummy plugs if so equipped.
You need to air test.
2006 F250 LARIAT CCSB 4X4
ARP Studs, O-Ringed Heads
X4 PHP 65 HP Custom Tow Tune
Atlas40
CAT EC-1 Coolant, IPR Coolant filter
BPD Waterpump
Fass-125 to a Adjustable Pressure Reg.
Turbo-back SS 4" pipe, Corsa Muffler -7" Tip
6.4 starter, DC Power 270 w/ AGM regulator
Die Hard Platinum AGM all 2/0 Cables
Fabtech Radius Arms
7" lift w: Icon Progressive Coil Springs
2008 up Carli/Deaver rear springs
2000 Watts of McIntosh Bliss
All riding on some Fatty-Daddy 38/15.50/18 Toyo's
mhatlen is offline
post #3 of 8 Old 02-19-2014, 12:40 PM
Mine is doing the same thing. Did you have any resolution?
2005 PSD Crew Cab Lariat/FX4. 315/70/R17 BFG AT/KO on Procomp wheels, cold air intake, 4" MBRP turbo-back minus kitty, EGR delete, Powermaxx turbo, SCT.
1997 Jeep TJ 6" lift, Ford 8.8 rearend, 4.56 gears, Detroit locked front/rear, 36" Swampers
damuddog is offline
post #4 of 8 Old 03-08-2014, 10:23 AM
I replaced the FICM with one from Bulletproof Diesel and no change in the truck. Where should I be looking now?
damuddog is offline
post #5 of 8 Old 03-09-2014, 01:43 PM
5-Salt's Avatar
IPR Valve, ICP Sensor or FICM sync is usual suspects if FICM voltage is at 45-48V at key on and during crank. See below below videos for excellent troubleshoot on this subject
6.0 Crank - No Start Diagnostics:
Strong like Bull - Smart like Tractor....
5-Salt is offline
post #6 of 8 Old 03-09-2014, 06:35 PM
Huge Mythical Beast!!
LoxDiesel's Avatar
Quoted: 331 Post(s)
Its sounds like a High Pressure Oil leak. Do you or know of someone that can hook up a scanner with data to check the high oil pressure while cranking?
Sent from AutoGuide.com App
@loxdce
LoxDiesel is offline
post #7 of 8 Old 03-19-2014, 09:15 AM
Update: Bad ICP sensor. Unplugged it and it would crank right up. Replaced it. Also had 4 bad injectors. Truck runs great now.
damuddog is offline
post #8 of 8 Old 03-19-2014, 11:58 AM
LoxDiesel's Avatar
Quoted: 331 Post(s)
Glad you got it goin
@loxdce
