How much blow-by is normal? - Ford Powerstroke Diesel Forum
post #1 of 13 Old 08-26-2008, 02:27 PM Thread Starter
dieselkane's Avatar
Hello all again. I have a quick easy question this time. How much blow-by are you guys getting out of the oil fill cap with the engine running? A buddy was wondering how much is normal on his 7.3, because he noticed smoke out of the oil fill cap. I also get a fair amount of smoke, but if you put your hand over it, there isn't a lot of pressure blowing out. Are whiffs of smoke normal on an engine with 60k miles on it? The 7.3 has something like 250k miles on it. Thanks!
Traded.. 03 6.0 PSD
For.. Black F250 2008 SD LARIAT 6.4 PSD 4x4, Aries Bull Bar, Westin chrome running bars, Dura Liner, B&W Gooseneck hitch, Recon smoked taillights, Icon 4.5" lift, 35" Toyo M/T, etc... Running Spartan Tunes
AFE PG 7, Flo Pro 4" DP Back, thanks to Cobb's Diesel. It has been great so far.
Originally Posted by azkcr View Post
So all that work and you're keeping the trash can of doom on the exhaust?
dieselkane is offline
post #2 of 13 Old 08-26-2008, 02:45 PM
If it aint a CAT itsa DOG
dieseldan2005's Avatar
I think the test is to put the cap on the spout upside down and if it blows off you have excessive blow by. My truck smokes pretty good and i only have 91k on it. I think the 7.3's all have a fair amount of blow by.
Diesel Dan
10,000 LAKES CHAPTER MEMBER
2003 F350 Crew cab long box, FX4, 6.0, torqshift, Lariat.
dieseldan2005 is offline
post #3 of 13 Old 08-26-2008, 04:30 PM
npccpartsman's Avatar
Quoted: 5 Post(s)
I asked this question too, because I have a what I thought was a significant amount of blowby, but Scuffy says it's normal for my 119K mile truck. It's enough to see at a stop (I have the CCV mod). It pisses the drive through people off enough to make them close the window on me--LMAO
I Bleed Razorback Red
Ford Makes It, International Shakes It, Casserly Fuels It, KC Turbo Spools It, SCT Tunes It, and Trucks Unlimited keeps her Rockin the Road
npccpartsman is offline
post #4 of 13 Old 08-26-2008, 06:35 PM Thread Starter
dieselkane's Avatar
I will go try the test. My guess is that the cap will stay on mine, but maybe not the 7.3. I suppose blow-by is not as much of an "issue" on diesels, is that about right?
Traded.. 03 6.0 PSD
post #5 of 13 Old 08-26-2008, 06:47 PM
Jon
Guest
Posts: n/a
Quoted: Post(s)
BB
Blow by is normal on a diesel to an extent. You will see some when you take the cap off. But you can tell the difference between a lil bit and excessive.
post #6 of 13 Old 08-26-2008, 08:04 PM Thread Starter
dieselkane's Avatar
So if you hold your hand over the oil fill, is it "normal" to feel pressure? Mine smokes out of it, but I cannot actually feel air blowing out. Where as some engines, (like our 1975 diesel massey tractor) have a lot of blow-by, to the point where you can hardly hold your finger over the CCV hose that comes off the valve cover.
Traded.. 03 6.0 PSD
post #7 of 13 Old 08-27-2008, 03:35 PM
I would say your just fine. I have seen some road tractors that the ccv dumps out under the engine and they were smoking like a steam locomotive. Like i said before, mine also smokes out the cap and like Jon said its normal for diesels to do just that.
Diesel Dan
post #8 of 13 Old 08-27-2008, 03:54 PM
Mob boss
Jarrod B's Avatar
Quoted: 149 Post(s)
what would cause the blow by?? my 97 has some.
2006 Ford F250 CCSB FX4 6.0
Sold
1997 F350 CCLB 2WD 7.3
1999 F350 CCLB 4WD 7.3
2003 F350 CCLB FX4 6.0
LSP Chapter Director
LSP Group Threads
Jarrod B is offline
post #9 of 13 Old 05-02-2009, 02:39 PM
Motown Fire's Avatar
Bump cause I have the same question....
Delmar Expedited Transport
Oil Field Freight & Hot Shot Services
Motown Fire is offline
post #10 of 13 Old 05-02-2009, 07:46 PM
Powerstroke Techie
forddieseldoctor's Avatar
excessive wear in the cylinders is the cause of blow by.
Ford Senior Master Diesel Tech
IF YOU DON'T WANNA STAND BEHIND OUR TROOPS
THEN FEEL FREE TO STAND IN FRONT OF THEM
Meet Double Aught
2000 F250
forddieseldoctor is offline
