'05,not boost, p2262 code - Ford Powerstroke Diesel Forum
post #1 of 14 Old 08-23-2008, 05:42 PM Thread Starter
i have a 05 f250 in my shop that is really getting to me. it has no boost and i cant seem to get any answers. on friday i removed the turbo and disassembled it and cleaned all the deposits in the vane area as the tsb describes. it was not to dirty but had some so i though i had found the problem. after putting it back on the truck, still no boost. the turbo is spinning but will not spin fast when accelerating. i see alot of people replacing turbos on this site. in the past a turbo was good untill it stoped spinning or leaked real bad. i am aware that there is a accuator in the turbo that is controlled by the solenoid on the turbo. do the accuators leak in the turbo which causes them to get replaced because they are "bad". are all these turbos getting replaced because they dont spin or they have a accuator problem? any ideas????
01 cummins 2500..lots of mods...SOLD
99 f350 4x4 dually crew cab, 4" straight pipe, ts 6 pos. 22.5 accurides, level kit,
IMPORTS ARE LIKE TAMPONS, EVERY P**** HAS ONE!
dragrcr1005 is offline
post #2 of 14 Old 08-23-2008, 05:45 PM
Rob
Rob's Avatar
Quoted: 2 Post(s)
im on my 4th i believe, and it was all due to " sticking vanes " it would cause a high or low boost condition... which was caused by a bad EGR valve not opening and closing properly, that is what i was told by the techs at the dealership....
Audentes Fortuna Juvat
(Fortune Favors The Bold)
The Org. Staff reserves the right to
move, modify, delete or merge threads/posts
at our discretion, without explanation
at any time.
Rob is offline
post #3 of 14 Old 08-24-2008, 07:58 AM
smokinstroke99's Avatar
look at egr valve. more than likely stuck open
smokinstroke99 is offline
post #4 of 14 Old 08-24-2008, 07:09 PM Thread Starter
egr is new. i removed it and re-checked it and it is closed and clean. the vanes in the turbo are clean and the ring will slide with no problem.
post #5 of 14 Old 08-24-2008, 07:18 PM
ADMIN AND TECH
SCUFFY828's Avatar
i dont see the egr causinga p2262 , im curious if the port running from the intake to the map sensor , is clogged up, pull the ruber hose off the intake and blow thru it and se if its clogged up, id start there
ITS STOCK
SCUFFY828 is offline
post #6 of 14 Old 08-25-2008, 04:40 PM Thread Starter
problem solved. clogged cat. converter pipe. thanks for the info. i will have to keep this one in mind for future reference.
post #7 of 14 Old 05-30-2009, 03:56 AM
EMVT's Avatar
heh.. very interesting post. Being a Diesel I hadn't even considered the cat... but I guess I shouldn't think so narrow minded. What made you come to this conclusion?
I too have an 05 with this issue.. only code a 2262.. it's an ambulance so I just replaced the turbo (If it weren't I would've just cleaned it) I did the BG EGR service and replaced the EGR.
The more I think about this the more it makes sense. When I fire this us cold this truck runs like a raped ape. But as soon as it heats up it's a dog.
I think this too could be it.. thanks for this post!
(60) 06-09 E-350 6.0 Ambulances
1999 Dodge Ram 2500 5.9 CTD
2000 Volkswagon Jetta TDI
2006 Mercedes 320 CDI
2004 Honda Shadow Sabre - 1100
EMVT is offline
post #8 of 14 Old 05-30-2009, 08:30 AM
Powerstroke Techie
m-chan68's Avatar
Quoted: 3 Post(s)
I would tend to agree with that statement. This reminds me of one of my MANY jobs where it set a hard P2262 upon reassembly. Sure enough, the mistake I made was reconnecting the the MAP sensor hose to an adjacent intake stud instead of the actual MAP sensor port. That one threw me for a loop.
Ford Diesel/Senior/Master Tech who placed 2nd overall in Ontario on the Fix-It-Right-First-Visit score for 2010
....who works at a dealership that now employs SOME half decent looking female employees since they overhauled most of the administrative staff
....but STILL loves hot women with big boobies
....and STILL hates working on E-Series with 6.0L
m-chan68 is offline
post #9 of 14 Old 05-30-2009, 08:35 AM
Powerstroke Techie
m-chan68's Avatar
Quoted: 3 Post(s)
Yes, I have come across this issue MANY times. All too often, too many people read on the internet that turbos are problematic with these vehicles, so they jump the gun and replace what is potentially still a good turbo. The quickest and easiest way to diagnose this, would be to disconnect the downpipe from the converter and road test to see if it improves.
If you attempted to rev the engine up in PARK, a clogged converter will cause engine RPM to increase, and then decrease steadily as you hold the accelerator.
m-chan68 is offline
post #10 of 14 Old 05-30-2009, 09:41 AM
EMVT's Avatar
Thank god I haven't done that yet... but I'm not above not doing it in the future... and I enjoyed that laugh! I have done similar stupid things though... in the end kicking yourself in the ***.
What's the big deal about 6.0's in an E-Series? besides the fact that you can't fit a deck of cards around the motor... and everything under the sun goes wrong with them taking far too many hours and blood to replace? Besides that... and the hours of cursing out the engineers... oh and the... and the...
OK.. you're right....
EMVT is offline
