egr delete/ oil cooler no start - Ford Powerstroke Diesel Forum
post #1 of 4 Old 10-26-2013, 05:51 PM Thread Starter
Angry egr delete/ oil cooler no start
i did a sinister egr delete kit and new oil cooler last weekend and now it wont start, ive cranked it for the last 4 days now with no results, replaced both the icp and ipr, im getting fuel pressure and oil pressure, and it blows a little smoke but itll just sit there and crank all day, I check the ficm voltage its at 48v, Im clueless... triple check everything what am I missing
devon8762 is offline
post #2 of 4 Old 10-29-2013, 06:45 PM
Gus_hauler's Avatar
I saw no one replied to your request, so I thought I'd take a shot.
1. Did you do a complete oil change? did you refill enough?
2. Did you hook back up the injector harness correctly to the back of the ficm?
3. Are you getting any error codes?
4. Any sensors unplugged?
2004 F-350 Crew Cab LB Dually
"Longhorn Hauler" edition
New Heads!
ARP Studs
Banks Six-Gun with PowerPDA (For gauges only)
EGR Delete from IPR
Rotella ELC
New Turbo from Garrett
Gus_hauler is offline
post #3 of 4 Old 10-30-2013, 12:15 PM
take out your oil filter and crank the truck. does the housing fill up with oil?
jeby64 is offline
post #4 of 4 Old 10-30-2013, 03:28 PM
also, what brand oil filter dd you use? I have noticed some filters aren't long enough to press the button in the bottom of the housing to allow the oil to go to the hpop. if its not long enough to press it, no oil, therefore no hp oil.
jeby64 is offline
