Hpop problems 03 - Ford Powerstroke Diesel Forum
post #1 of 19 Old 10-26-2013, 06:13 PM Thread Starter
Hpop problems 03
Alright I've finally saved some money to get some work done on my truck I've narrowed it down to the hpop but not sure if its just a leak or the hpop is bad I was wondering if there's anyway I could take r to the dealership and find out for sure or what? Also would the hpop cause a intermittent miss? Thank you
Unknown is offline
post #2 of 19 Old 10-26-2013, 06:22 PM Thread Starter
Any answers would be greatly appreciated
Unknown is offline
post #3 of 19 Old 10-26-2013, 06:34 PM
Mod Newbie
dhanna6powerstroke's Avatar
Quoted: 19 Post(s)
What kind of problems are you having that you have determined a bad or weak HPOP?
dhanna6powerstroke is offline
post #4 of 19 Old 10-26-2013, 08:14 PM Thread Starter
No hot start and the miss
Unknown is offline
post #5 of 19 Old 10-26-2013, 08:15 PM Thread Starter
And I had the turbo replaced not long ago and I asked the mechanic about it and he used to own the truck and told me that's what it was it was going bad when he had it
Unknown is offline
post #6 of 19 Old 10-26-2013, 09:45 PM
Mod Newbie
Quoted: 19 Post(s)
Do you have a way to monitor your parameters? You need to see what your ICP is when trying to start it hot. It has to see a minimum of 500 psi to start. You could try unplugging the ICP sensor and seeing if it will start but if it's an early 03, it'll be hard to get to, especially when it's hot.
post #7 of 19 Old 10-27-2013, 06:10 AM Thread Starter
No. I was thinking on taking it to the dealer for that and i I've looked into the icp sensor it looks almost impossible to get to
Unknown is offline
post #8 of 19 Old 10-27-2013, 06:25 AM
Mod Newbie
Quoted: 19 Post(s)
The 03-04 models did have more pump issues than the 05-07years. You can move your degas bottle out of the way and the FICM and get to it.
post #9 of 19 Old 10-27-2013, 06:36 AM Thread Starter
If I unplug it and it starts what does that mean?
Unknown is offline
post #10 of 19 Old 10-27-2013, 06:37 AM
Mod Newbie
Quoted: 19 Post(s)
The sensor is junk. The 03's are also notorious for oil leaking through the sensor and contaminating the connector with oil. If it starts, replace the sensor and pigtail.
