Help! Under my truck right now! Can you remove CKP sensor without removing AC compres - Ford Powerstroke Diesel Forum
post #1 of 4 Old 10-26-2013, 06:28 AM Thread Starter
I took off the front pass side wheel and splash guard to change a glow plug and was going to change out the CKP sensor too since I got a code for it. Can I get to it without removing the AC compressor? Not comfortable doing that.
I know other things can give a CKP code, but I have stuff taken apart and have the new sensor in hand.
2005 F-250 Lariat CCSB 4x4 -
ARP Headstuds
EGR delete
Blue Spring
Edge CS
Sinister Coolant Filtration
4" Diamond Eye Turbo Back, Straight Through
6.0_n00b is offline
post #2 of 4 Old 10-26-2013, 08:24 AM
I Like Shiny Things :)
nighthawk285's Avatar
Quoted: 1669 Post(s)
Feedback Score: 4 reviews
Why don't you just remove the bolts and place it to the side. As long as you don't loosen the lines, none of the freon will escape and you don't have to recharge it.
2005 King Ranch F-350: Studded and O-Ringed, BPD Oil Bypass, 205/30s, Stage 2 KC Turbo, ODAWG Ported Manifold, 4" TB Exhaust, No Limit Intake, Billet Torque Converter, BPD 58V FICM, BPD Water Pump
2.5" Leveling Kit, 35s, Fusion Bumpers, ProTech Headache Rack, OnBoard Air, and a few other goodies
nighthawk285 is online now
post #3 of 4 Old 10-26-2013, 08:30 AM Thread Starter
I'll try that tomorrow. I had to put her back together because I have some errands to run.
Thanks for the tip. It seems so obvious now that I think about it... derp
ARP Headstuds
EGR delete
Blue Spring
Edge CS
6.0_n00b is offline
post #4 of 4 Old 10-26-2013, 08:32 AM
No problem, sometimes its the easy stuff that seems the hardest
