help plz - Ford Powerstroke Diesel Forum
post #1 of 2 Old 10-25-2013, 06:17 AM Thread Starter
farmall1066's Avatar
help plz
Went to start my truck this morning, everything cycled and held key on and nothin. Held it for 10-15sec tbc light came on. Turned key off repeated cycle and turned key and got a slow crank. Turned key off and the starter continued to crank. Popped hood and unhooked grounds on my batterys. Waited awhile and hooked batterys back up and went and put the key on and nothing, no lights, no door bells. Can someone help me
farmall1066 is offline
post #2 of 2 Old 10-25-2013, 06:23 AM
Term3's Avatar
Do you have anything to check the voltage on your batteries? It's possible a plate shorted out on one battery and discharged almost all the power on the other one. Other then a bad ground cable I can't think of anything else that would kill everything.
Sent from AutoGuide.com App
SCT, no studs...yet, Dual OEM intake air filter housings, Banks intercooler & intake elbow, Banks exhaust system, Windrunner ported intake manifold, Bullet Proof Diesel remote oil cooler & thermostat, AirDog2 (plus a couple spares), Power steering filter (Amsoil dual-bypass), MagTec deep ATF pan, Electric oil pre-lub pump, Dakota Digital gauges.
Term3 is offline
