Looking for suggestions... - Ford Powerstroke Diesel Forum
post #1 of 9 Old 10-24-2013, 06:08 PM Thread Starter
Ok guys Im working on a 03 f450 2wd dump. It has around 120k miles and is fleet maintened and operated by people who really don't have a clue whats going on so let me start with the whole scenario.
-original complaint came in that the truck would randomly shut off and would restart after sitting for a while. Was towed to the shop were we could not get it to act up, however while driving it the truck would really not get up and go,turbo would spool up fine but almost felt like something was holding it back from climbing rpms quickly. (little black smoke from exhaust under hard acceleration)
-had another truck at shop with a brand new ficm in it so I swapped ficms fast to see if that took care of it
- took vehicle out on a long test drive running for parts, sure enough it dies on me. I could get it to restart by unhooking batteries and hooking them back up after sitting for a few mins. drove truck a few more miles died again. had towed back to shop.
-swapped old ficm back into truck, gave other truck its new ficm back.
- did a little research, change IPR, and ICP and harness while I was at it.
- test drove truck again, ran good/smooth but still felt like it lacked power. another guy at shop took for a parts run again. said it started real hard at his last stop and had to give it some throttle to get it to fire.
- the whole time the truck had the ficm from the other truck in it it ran fine and never had any problems starting. so I swapped in a new ficm from ford(reman).
- now the truck does not start at all, or will crank for a very long time, finally come to life, run for maybe 10 mins at idle and start to spit and spudder and then eventually die and not restart.
I was thinking that possibly the new ficm was faulty but it is reading 48v. I also had to put an alternator on it because while checking the ficm voltage I found the alt was not charging, so I replaced alternator and gave batteries a full charge.
So now that it still will not run, Im looking for new ideas, anybody have any?
mammarellom is offline
post #2 of 9 Old 10-24-2013, 06:18 PM
Bluedemon6.0's Avatar
Send a message via Skype™ to Bluedemon6.0
this to me sounds like an egr valve sticking because it will start after it sits.
-Steven
New!! 2015 Mustang ecoboost!!
Sold!!
formally owned:04 6L PSD CCSB
Studs
Egr delete
S&b intake
New dashboss with fuel pressure and egt
Sct Looney by Vivian and Tonywildman xtreme early lock up now
php 140x
63.5/88mm 06 turbo with a pmax billet WW2
PHP Atlas 80
My baby-
87 jeep wrangler
350 and 700r4 built by mad dawg transmission
Dyno @ 200hp and 400ftlb at 3100 rpm
On 33s
Bluedemon6.0 is offline
post #3 of 9 Old 10-24-2013, 06:19 PM
Try this link.
No start issue? Look here.
-Steven
Sold!!
Studs
Egr delete
S&b intake
php 140x
PHP Atlas 80
My baby-
87 jeep wrangler
On 33s
post #4 of 9 Old 10-25-2013, 04:42 AM Thread Starter
after looking through the link, I removed the egr valve today and cleaned it. was not overly dirty or gummed up like others I have seen. i want to do the egr check on the laptop but I cant get the truck to run long enough to get up to temp. is there a way to manual check the valve by giving it voltage out of the truck? also checked icp pressure and was well over 500. it ran for about ten minutes this morning after starting hard and was a little shaky at idle but not terrible and once i shut it off it now just cranks. I also changed oil and fuel filters along with the engine oil. can anyone help any further? thanks!
post #5 of 9 Old 10-26-2013, 02:37 AM
Fill it up again Dummy
mhatlen's Avatar
Quoted: 465 Post(s)
Garage
Do you have monitoring for the engine??
A ScangaugeII does a very good job.
It will monitor egr desired and actual position.
ICP should be in the 800 range once started you also need to watch the IPR values. It should be around 20% at idle.
Battery voltage at cranking should be 10+ volts. If you see it below 9 volts it's not going to start because the FICM requires 8.5 to turn itself on.
I know you now are having a no start. The FICM logic board may be your issue. I would do a swap with a FICM you know works. Even if you see 48 volts, it is rare but the logic boards do go bad sometimes.
If you cannot start it with a good FICM you must start looking at icp/ipr. Cranking voltages
2006 F250 LARIAT CCSB 4X4
7" Icon/Carli Lift
ARP Studs, O-Ringed Heads
X4 PHP 65 HP Custom Tow Tune
Atlas40
2000 Watts of McIntosh Bliss
mhatlen is offline
post #6 of 9 Old 10-26-2013, 03:48 AM
Mod Newbie
dhanna6powerstroke's Avatar
Quoted: 20 Post(s)
Any smoke at idle when it IS running?
dhanna6powerstroke is offline
post #7 of 9 Old 10-28-2013, 09:39 AM Thread Starter
Hey guys I did some further digging and am pretty sure the hpop is causing me the issue. When it runs my icp value is around 750 psi and my desired is 850 psi. My ipr is almost 85%!
On its brother truck i was getting readings of 1100/1100 and 23%
When it will not run my icp is under 500 and my desired is over 1000. Sound like hpop to everyone else?
post #8 of 9 Old 10-30-2013, 12:02 PM
AshevilleEngine.com's Avatar
Quoted: 2 Post(s)
Sounds like a HPOP over heating. Make sure that you put a new oil cooler in it too.
AshevilleEngine.com is offline
post #9 of 9 Old 10-30-2013, 03:34 PM
first, egr will not cause a no start. pull it out or wedge it open, it will run like crap but still run. 03s have a big issue with hpops. so it might be a safe option. not trying to shoot everyone else down or anything, but yeah 03s down have many other places for hp oil leaks.
jeby64 is offline
