6.0 Starting Problems - Ford Powerstroke Diesel Forum
post #1 of 3 Old 10-24-2013, 11:52 AM Thread Starter
Gentlemen/Ladies,
I am a diesel rookie but I now own a powerstroke 2006 F350 SuperDuty with a 6.0. I am experiencing a starting problem that I need your advice about. Everything has been going good until 2 days ago. I started to drive it and all of a sudden it started jerking and bucking like I had bad fuel going thru. Since I was at about at a 1/4 tank I thought that might be the problem so I stopped and put some fresh fuel in. Yesterday it ran find, no problems. Now today I can't get it to start.
Any suggestions as to my problem. All filters were changed last fall, along with oil change and coolant flush.
Thanks for your help.
Mike
mward3 is offline
post #2 of 3 Old 10-25-2013, 08:40 AM
Fill it up again Dummy
mhatlen's Avatar
Quoted: 441 Post(s)
Garage
Check the ficm voltage, you will need a monitor of some sort. ScangaugeII is available at Auto Zone for around $165.00 and monitors almost everything on the 6.0.
it needs to be in the 46-48 volt range to be solid if the truck has had a bad battery recently that will wipe out the ficm.
Start there plus engine needs to be in the 10+ volts during crank for it to start good. At 8.5 volts and lower it will not start, this can all be monitored by Scangauge.
2006 F250 LARIAT CCSB 4X4
ARP Studs, O-Ringed Heads
X4 PHP 65 HP Custom Tow Tune
Atlas40
CAT EC-1 Coolant, IPR Coolant filter
BPD Waterpump
Fass-125 to a Adjustable Pressure Reg.
Turbo-back SS 4" pipe, Corsa Muffler -7" Tip
6.4 starter, DC Power 270 w/ AGM regulator
Die Hard Platinum AGM all 2/0 Cables
Fabtech Radius Arms
7" lift w: Icon Progressive Coil Springs
2008 up Carli/Deaver rear springs
2000 Watts of McIntosh Bliss
All riding on some Fatty-Daddy 38/15.50/18 Toyo's
mhatlen is online now
post #3 of 3 Old 10-25-2013, 08:50 AM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
I would change the fuel filters as well. Maybe you clogged them up running the tank low. Get a monitor and record Icp volts, IPR % and FICM with KOEO. I'd also find a way to check your fuel pressure.
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
