Motor ate turbo - Ford Powerstroke Diesel Forum
post #1 of 3 Old 10-22-2013, 11:17 AM Thread Starter
Motor ate turbo
Loud screeching noise, lots of blue smoke. Shut truck off, now won't start, not building oil pressure. I am thinking that pieces of the turbo went into the oil pan, and took out the LPOP. I am going to drain oil, remove LPOP and turbo. Any tricks to removing the oil pan and pickup?
rdr99 is offline
post #2 of 3 Old 10-22-2013, 11:39 AM
The low pressure pump is mounted externally on the crank in front of the front cover the pan does not need removal to service the pump.
Now if your removeing to look for pieces that is another matter.
By the way there are not many ways that turbo pieces can get into the pan, it is externally mounted to the engine and oil gets to it thru a tube only to the shaft bearings.
Lord I shall lead them to the water but I will not try to make them drink
dannyboy950 is offline
post #3 of 3 Old 10-22-2013, 02:54 PM Thread Starter
Pretty sure I need to look for pieces in the oil pan.
rdr99 is offline
