Coolant 'burp' when degas uncapped - Ford Powerstroke Diesel Forum
post #1 of 7 Old 10-22-2013, 06:57 AM Thread Starter
Hey guys-
2006, with SCT Looney, got the EGR and everything.
I've noticed the truck seems to have been running 10* warmer for the most part- AND
If I open cap on the degas, occasionally it will blarp out coolant, like there's air somewhere in the system pushing it out.
Coolant hasn't been needed to be added in the past 10K miles I've put on it, pulling a camper and such, and I don't see any sort of residue around the cap..
It should be noted I always fill it on my driveway, to the high mark, and that's at an incline so I might be overfilling..
Could this be the incipient stage of a headgasket issue? Or am I just paranoid?
I'm taking it apart now for the dummy plugs/standpipe/EGR/STC work, thinking about going all the way and doing heads now as well.
Greg
Thunderpimp is offline
post #2 of 7 Old 10-22-2013, 07:06 AM
Fummins90's Avatar
Is it the original cap or the updated ford one with orange writing and the yellow "updated fill line approximately a half inch below the old fill line?
-Jacob
PowerHungryPerformance --
Comments or opinions expressed by me do not necessarily represent the views of PHP, its management, nor its employees. PHP is not responsible for, and disclaims any and all liability for the content of comments written by me.
Fummins90 is offline
post #3 of 7 Old 10-22-2013, 07:08 AM Thread Starter
It's the original.
Didn't know there was an update to that one- I'll have to pick it up, as I understand these things fail pretty often..
post #4 of 7 Old 10-22-2013, 07:15 AM
Fummins90's Avatar
Originally Posted by Thunderpimp View Post
It's the original.
From my knowledge, they updated it to a lower pressure release to prevent the coolant burp.
-Jacob
post #5 of 7 Old 10-26-2013, 09:09 PM
The old caps purge at 15 psi, new ones at 16 psi. If the cap pops when you take it off, thats normal, if it feels like its about to take your hand off, thats a sign to at least test coolant psi. If its bubbling air into the degas, it might be from either two small hoses going into the top of the degas but shouldnt be. If you are getting air into your block, thats very bad. That might mean a pump issue??? (Someone else might answer that), or a common problem, one I noticed with ELC type coolant, is that less than 50/50 can flash boil inside the block, causing air pockets. I always use the old fill line and even with a bad HG it never ever "burped" it just shot the cap off everytime I opened it after driving. I would try to isolate where the pressure is coming from, and look at making a $20 collant gauge just to see (very crude, not something to keep on)
468 HP & 873 Ft-Lbs
2005 F-350 SRW 4x4 CC Long Bed
SPD tune by Chris @ Truck Source Diesel
ARP Head Studs
3.5" DP to 4" Straight Pipe
Banks High Ram Air Intake
K&N CAI
Edge Evo CTS w/ Backup Camera to monitor
MTS HD Direct Drive Solenoid
Updated:
Standpipe & dummy plugs
Turbo feed & drain tubes
HPOP & IPR screens
Blue Spring
ajfrac is offline
post #6 of 7 Old 10-27-2013, 07:12 PM Thread Starter
Good ideas.
I watered down the coolant pretty good when I had a coolant leak with my filter install...
post #7 of 7 Old 10-27-2013, 07:44 PM
I would get an electrolometer from autozone for like 2 bucks, compare the freezing pint with the chart on any coolant bottle, theyre all the same when it comes to freeze points. After I did my HG and studs I was running about 43/57 and I was still getting high psi, got it at 65/35 now and I cant get it above 8 psi. Hot tunes will increase the hotspt temps of your cylinders too. Id check your coolant ratio and go from there
468 HP & 873 Ft-Lbs
ARP Head Studs
K&N CAI
Updated:
HPOP & IPR screens
Blue Spring
ajfrac is offline
