Need help, 6.0 Running issues - Ford Powerstroke Diesel Forum
post #1 of 5 Old 10-21-2013, 05:18 PM Thread Starter
IamMonsterMan's Avatar
This just happened out of nowhere today and I'm not really sure what the issue is.
I drove about 30 minutes from work to the town I live in, went to 2 different stores and the truck started and ran fine.
I go home to get ready to go to my girlfriends house and I go to start it and it starts and runs at about 250 rpms for about 3 seconds and dies.
I try again and same thing, so I let it cool off for a little while thinking maybe its the HPOP that died
It started sluggishly but eventually the RPM's came up to normal and it started idling normal. I give it some pedal and it revs up normal but then bogs down and goes back to a normal idle.
Then i shut it off and scanned for codes, all I got was for EGR because I have it deleted and I havent been running any tunes for a while because the vanes are stuck in my turbo and i havent gotten around to changing it out yet.
I start it again and look back and notice a pretty good amount of oil smoke is coming out of the stack at idle, so I shut it off.
Start it one more time and now theres no pressure on the dummy gauge in the cluster.
So to me this seems like multiple problems all happening at once, but it does seem like an oil issue somewhere
Any help and knowledge would be appreciated, this is my only means of transportation.
A little info on the truck
-04 6.0
-75000 miles
-EGR delete
-It started to overboost about a month ago so I took the tune off and have been babying it, I have another turbo to put in, time hasnt allowed me to do so yet.
Haven't really had any other issues with the truck since I got it a year or so ago
'04 F-350 6.0 4x4 Reg. Cab Long Bed (SOLD)
Billet Torque Converter || EGR Delete || Airaid Intake || Catless & Mufflerless || 4" Downpipe || 5" Sidepipe w/ 6" Tip || SCT X4 || 35" Hankook Dynapro MT's on 16" Ion's || XDP Coolant Filter || Kenwood Head Unit || 2014 Tailgate
IamMonsterMan is offline
post #2 of 5 Old 10-21-2013, 08:59 PM
Fill it up again Dummy
mhatlen's Avatar
Quoted: 485 Post(s)
Garage
The overboost needs to be dealt with or head gaskets will be next on your list. I am assuming your ficm is fine. I am thinking injector but need to look at icp ipr ficm.
Can check exhaust manifold temps if you have IR temp gauge at each exh port
2006 F250 LARIAT CCSB 4X4
7" Icon/Carli Lift
ARP Studs, O-Ringed Heads
X4 PHP 65 HP Custom Tow Tune
Atlas40
2000 Watts of McIntosh Bliss
mhatlen is online now
post #3 of 5 Old 10-22-2013, 01:58 PM Thread Starter
I took the ICP sensor out and cleaned it out and changed the oil and now it seems to be starting and running fine. EGT's were always fine on my gauge, never above 1000 with normal driving.
My question is is there supposed to be a screen or anything on the ICP sensor? When I took it out there wasn't one. If the same problems happen soon enough i'll just replace the sensor. There was no oil in the plug when I took it off either.
And yes, throwing the new turbo in is on my priority list, without tearing half the engine apart is there anything else I should do while the turbo is out?
post #4 of 5 Old 10-22-2013, 02:02 PM
PHYRMN's Avatar
ICP's dont have screens, IPR's do though.
2011 F350 King Ranch DRW No Mods Yet
SOLD 2003 Excursion Eddie Bauer 6.0l 4x4 | 2004 Intake | Zoodad Mod | Upgraded HPOP Cover | ARP Studs | OEM Headgaskets | Updated Turbo Feed-Drain Tubes | EGR Delete | Coolant Filter | Altas 40 | MKM Street Tune | Banks 4" CAT Back | Muffler Delete | High Idle Mod | Blue Spring Update | 6.4 Banjos | CCV Mod | Glowshift Gauges (Boost, Oil Press, Coolant Press, EGT, Volts, Fuel Press) | Rotella ELC | Rotella T6 | V/B Springs | Torque App on ASUS 10" Tablet |
PHYRMN is offline
post #5 of 5 Old 10-22-2013, 05:05 PM
Had a very similar issue. Turned out the screen in the IPR was damaged causing sporadic issues similar to yours
seanhoffman is offline
