2003 F350 6.0 White smoke on cold start only?? - Ford Powerstroke Diesel Forum
post #1 of 9 Old 10-21-2013, 09:00 AM Thread Starter
Hey guys, I noticed that the last 2 times I cold started my 6.0 I get a little white smoke from the exhaust for about a sec or 2 and after that the truck just does what it should. Its not like a huge cloud but just a little smoke. It just started recently too within the last 2-3 weeks. I dont drive the truck much only on weekends but seems very abnormal to me. I never had a single issue with the truck since I owned it. I monitored coolant temp and what not but there seems to be nothing wrong with the truck, no power loss no coolant dissapearing no nothing. It smokes a little black when u get on er on the highway but im pretty sure thats normal. Its only on start up when its cold. White smoke Dosnt smell like coolant however the smoke sticks aroud for a while so its not condensation. I pulled the egr last week and I had a hard time getting it out. Its was clogged up. Valve wasnt operating to my knowledge. Egr was dry so was tge intake under it. I cleaned her up and seems to work now. However it didnt fix anything. Still smokes a bit on startup. Just got a new airfiler and truck just had an oil change. Did the fuel filters maybe 500km ago and drained the fuel water seperator. I dont know what might be wrong. The only thing I can think of and I dont want to thing about it is a cracked block. A little crack that lets in coolant when cold and once it warms up crack closes and its all good, only problem with this diagnosis is that the white smoke dosnt smell like coolant. I heard unburnt diesel fuel smokes white? Injectors, turbo? Im at a loss here and need some help
6.OPowerstroke is offline
post #2 of 9 Old 10-21-2013, 11:14 AM
twoicebergs's Avatar
Quoted: 43 Post(s)
Don't know where you live, but it may be 100% normal since a gasser will do this on start-up as well when cool. A second or 2 is nothing to be concerned about, unless you notice moisture in the intake or smell fuel. Even the fuel smell is nothing to fear if it is very short lived on occasional starts.
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
post #3 of 9 Old 10-21-2013, 02:37 PM Thread Starter
Well we have an 09 f150 too but that is just condensation. The 350 definantely smokes because the smoke sticks around for a bit however like said above no hint of coolant. Just smells like diesel. I live in canada. Right now we get around 15 during the day and 2-5 celsius at night. Dosnt matter if I start the truck in 15 degree weather tough it still smokes when its warmer out in the afternoon. It just started happening recently though. Truck has 197k so about 123k miles
post #4 of 9 Old 10-23-2013, 12:09 PM Thread Starter
Bump! Hoping to figure out what this is. Might be ealry signs to a bigger problem. Also when I start the truck after it sat overnight it starts no problem but it sounds really wierd dadam dadam for a few seconds till it warms up but have had that going on for a while when the weather gets colder and was told thats normal. only recently the white smoke started.
post #5 of 9 Old 10-23-2013, 03:34 PM
Quoted: 43 Post(s)
It sounds like stiction issues. Perhaps your injectors are in need of cleaning or replacement.
Frank
Working for Toys
post #6 of 9 Old 10-23-2013, 04:06 PM
MoserJR82's Avatar
Couldn't agree more. I have an 05 F350 and it started doing the same thing at 125,000 miles. Original injectors in 6 of 8 cylinders. I live in Iowa and the mercury is starting to drop so my truck is starting to give a brief white puff of smoke in the mornings, even if I plug it in overnight. I just did studs and headgaskets 30,000 miles ago and it's still doing it when it's cold so I wouldn't worry about it too much if I were you.
What oil are you using? Have/do you use Rev-X? If you' haven't yet, I'd switch to a full synthetic oil. I just ordered Rev-X for my truck, so we'll see how it works out. LOTS of good reviews/posts about it on this forum so I'm confident it will help extend my injector life.
2005 F-350 KR, CC, SB 6.0L
Sinister EGR Delete
Final Charge Coolant
Rotella T6 5w40
Sinister Coolant Filter
MBRP 4" turbo back straight pipe
Blue Spring Upgrade
Droid Torque App
SCT X3 Spartan Hyrbid Race Tune
ARP Head Studs
Aftermarket degass cap
Cowl hood (not functional)
Atlas 80 PHP FICM tune
Rebuilt FICM thanks to FICMRepair.com!
Rancho RS9000X front shocks
MoserJR82 is offline
post #7 of 9 Old 10-23-2013, 05:08 PM
FJuanfiddy mod
Dave's Avatar
Quoted: 9 Post(s)
A brief white puff is normal dependent on temp and tuning
Email:
2006 F250 ECSB Lariat 4x4
Edge Insight CTS
Coolant filter
Dave is offline
post #8 of 9 Old 10-23-2013, 08:13 PM Thread Starter
Right now im running motomaster 15w40 non synthetic. ran the same oil last year whithout any issues. Just did a oil change couple of weeks ago, might be related?? I started a couple weeks back? Rev-x for fuel or oil? I do not use it but ill give it a try. The thing thats so odd to me is that last year I had no smoke whatsoever.
post #9 of 9 Old 10-23-2013, 08:59 PM
somthin333's Avatar
Mine also smokes when i start it up when its cold out. Rev-x didn't work in my case. I was thinking of trying this...
Fixing stiction
2003 6.0 F-250-ARP headstuds, Sinister egr delete and coolant filter, 4" turbo back exhaust, BPD oil cooler, Edge CTS monitor, IDP Tunes, Cooper STT tires
somthin333 is offline
