just some words of advice - Ford Powerstroke Diesel Forum
post #1 of 5 Old 10-21-2013, 07:47 AM Thread Starter
Ok guys so my dads 03 6.0 powerstroke was having problems and would die and stuff. So i did a whole bunch of research and went ahead and went for the hpop. So I tackled the job not knowing what i was getting into but forums for the win. I went ahead and put in new hpop and seals and gaskets for itm,egr and turbo and changed ipc and with the pigtail. So anyway what a pain in the arse it was but got her done. But on the first start the truck made a awfull loud crunching sound like im guessing were the gears meet up for the hpop and trans are something. But didnt ever do it again just that once. It could of also been the starter anyone else ever witness this. And finally when i go to start truck it wont start right up after the glow plug light goes off but will start everytime once you hear the fuel pump done priming so just guessing i have to drive it more only did 30 miles so far then maybe air will come out lines.
yfzrunner is offline
post #2 of 5 Old 10-21-2013, 08:00 AM
Beewoody's Avatar
I would imagine the HPOP (system) needs time to get the air out of the system. When I replaced mine ( 05 F250... same time as adding BPD oil cooler) it took a good 30 miles or more to get all the air out.
05 F-250 SD Crew Cab Lariat 6.0 PSD: BPD Oil Cooler, BPD Manual Fan Clutch Adapter with 7.3 fan, Built FICM powerboard w/Atlas 40, Gearhead's SRL, 8k Tow, Unlimited Tune, EGR Delete, Blue Spring Mod, 6.4 Banjo, Updated HPOP/STC, Updated Standpipes/Dummy Plugs, EC-1 ELC Coolant, Updated Turbo oil supply/return lines, Edge CT, 2.5" Readylift Level Stage 3, 35/ 12.5/ 18 TOYO AT2 Extems' mounted on 18" MB wheels and finally.... STOCK HEAD GASKETS
.... 203K miles on 10/3/2014...
Beewoody is offline
post #3 of 5 Old 10-21-2013, 08:43 AM Thread Starter
what about any loud crunching noise come from your when you went to start it. It scared the hell out of me lol.
post #4 of 5 Old 10-21-2013, 09:57 AM
twoicebergs's Avatar
Quoted: 47 Post(s)
It could have been the bendix from the starter, but only you would know where the sound came from. As far as it being the HPOP gear, you should have ensured the gear was meshed before torquing it down. If you suspect the HPOP gear, you will need to go back in and retorque it. I suspect, since it was very loud, that it was the starter not engaging correctly.
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
post #5 of 5 Old 10-21-2013, 10:08 AM Thread Starter
Yes as i was standing back waiting for anything to happen lol. It did sound like the area of the starter as the motor gets no fuel it sure does turn over real fast like. And the hpop did sit down nice and flat before i torqued it. And the sound has not came back since the first start and truck run better than ever. Except air in lines hoping it escapes lol.
