Smoke and uneven firing at idle - Ford Powerstroke Diesel Forum
post #1 of 12 Old 10-21-2013, 05:34 AM Thread Starter
Norwegian Viking's Avatar
Send a message via MSN to Norwegian Viking
Hello, and first, sorry about my bad spelling, i am from Norway :-)
I got som problems whit my 6.0 2003 (70000 miles)
its doing smoke and uneven firing at idle, when Cold over night.
It also make pressure in colant, so i think the head gasket blown, its comming more pressure if i use the engine harder.
The engine is running whit a SCT tuner, and i have don a EGR delet my self, just Welding the ends on the cooler.
What is the way to og now ? i thinking abut pulling the cab, and rebuilding the sylinder heads.
Is this kit the way to go, ore shoud i put the OEM cylinder gaskets ?
Ford 6 0 Powerstroke Black Diamond 20mm Head Gasket Replacement Arp Stud Kit New | eBay
I heard that i shoud stay away from the Black dimond gaskets, what you think ?
Maybe some one in her can hook me up whit a kit including everything i need ?
What about oil cooler, and fule pressure, shoud i do smothing about that also at same time ?
Appreciated tips and feedback on how and what I should do.
Norwegian Viking
(from Norway)
PS: pleas visit my gallery and leave a coment
No Smoke No Power, No Power No Fun, No Fun No Life !
F250 PSD 6.0 2003. SCT x3, Smittybuilt stainless bullbar, Rollbar, 31/75-16 Procomp All Terrain on Mickey Thomson Cassic II 10x16", Procomp 2" lift leafs front, F350 blocks in rear, Procomp MX6 adjustable.
Norwegian Viking is offline
post #2 of 12 Old 10-21-2013, 11:52 AM
Fummins90's Avatar
OEM Gaskets.
-Jacob
PowerHungryPerformance --
Comments or opinions expressed by me do not necessarily represent the views of PHP, its management, nor its employees. PHP is not responsible for, and disclaims any and all liability for the content of comments written by me.
Fummins90 is offline
post #3 of 12 Old 10-21-2013, 12:12 PM
shenanigans
junior125's Avatar
Quoted: 1506 Post(s)
Garage
with a 2003 you'll need 18mm gaskets instead of 20mm
Mike
2005 CCSB F250 4X4
O-ringed with H-11's, Irate T4, BW S363SX-E, Holders 175/30%, ODAWG S3R, TSD Tunes, No Limit Intake, CSF Intercooler, BPD Remote Oil Cooler, BPD water pump, 7.3 Fan Adapter, BD Diesel Manifolds, 6.7 Pump, Driven Diesel RR, Built Trans w/ PI converter, Derale Deep Pan, Traction bars, AirLift Helper Bags
junior125 is offline
post #4 of 12 Old 10-21-2013, 12:41 PM
Texas Proud
charlie.thomas's Avatar
A buddy and I just did a cab off last week on his truck, like the others have stated go with OEM gaskets. While doing the head gaskets go ahead and do the oil cooler as well and upgrade the hpop STC fitting also. Have your heads pressure checked for cracks and if they are good have a gasket mill done. If you can get away without having to do emission tests for state inspections I would also suggest doing the EGR delete kit as well. Also for a about $80 bucks go ahead and do the blue spring mod too, easy and cheap and better throttle response. Kits come with most every thing you need but if I remember correctly you will need to buy your injector O rings separately. We are working on putting a cab off thread together that will list and have pictures of taking everything loose to pull the cab and pulling everything apart for a head stud job, going back together you would just go backwards through the list. I'll let you know once we get it posted if you would like
"Feel the Fear and Do It Anyway"
2007 F250 King Ranch
Alligator Performance EGR Delete
5" AFE air intake
Blue Spring Mod
High Idle Mod
4" Turbo back straight exhaust
SCT Livewire TS tuned by the best, "Tony Wildman"
New block bored .020" over
New heads ported, polished, and decked
ARP Head studs
And other goodies
Lifted on 35" Toyo Open Country MT
charlie.thomas is offline
post #5 of 12 Old 10-21-2013, 02:38 PM Thread Starter
Perfect i need that :-)
Norwegian Viking
(from Norway)
post #6 of 12 Old 10-21-2013, 02:45 PM Thread Starter
Ok i do the hpop STC fitting, but tell me, why do i want to do that ???
Norwegian Viking
(from Norway)
post #7 of 12 Old 10-23-2013, 04:09 AM
Texas Proud
The factory one is a 2 piece fitting and over time will cause oil to leak and therefore messes up your oil pressure for firing the injectors. The replacement piece is a 1 piece fitting that eliminates the problems from the original fitting.
5" AFE air intake
Blue Spring Mod
High Idle Mod
ARP Head studs
And other goodies
post #8 of 12 Old 10-23-2013, 06:59 AM Thread Starter
Tanx fore that info m8 :-)
Norwegian Viking
(from Norway)
post #9 of 12 Old 10-23-2013, 07:48 AM
AAHHH of topic but ya always psrk in the living room or this was a special occasion?
Lord I shall lead them to the water but I will not try to make them drink
dannyboy950 is offline
post #10 of 12 Old 10-23-2013, 08:00 AM
Texas Proud
Lol, I never noticed that in the picture. Must've been a special occasion lol. Anytime for the info bud
5" AFE air intake
Blue Spring Mod
High Idle Mod
ARP Head studs
And other goodies
