Need help please! - Ford Powerstroke Diesel Forum
post #1 of 3 Old 10-20-2013, 12:56 PM Thread Starter
Kennyk123's Avatar
Need help please!
I am located in Columbus, GA and I just started having some issue with my 2006 F250 6.0. I believe the problem is my injectors but I want to take it to a reputable diesel shop that I can trust to check it out, since I plan on getting some other work done while it is in the shop as well. That is what I need help with, does anyone know any shops near by that they could recommend? I have found some up around Atlanta but I really do not want to get the truck towed that far up if I don't have to. Any help from anyone would be greatly appreciated.
2006 Ford F250
5" Diamond eye turbo back exhaust
Extreme street tune, from innovative diesel
ARP studs
EGR Delete
IPR Coolant filter
S&B Cold air intake
35" nitto terra grapplers
18" fuel hostage rims
8" suspension lift
Kennyk123 is offline
post #2 of 3 Old 10-20-2013, 12:58 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
What are the issue's? Do you have a monitor? Maybe we can help you fix it. The 6.0 is very DIY freindly.....
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #3 of 3 Old 10-20-2013, 01:27 PM Thread Starter
Kennyk123's Avatar
I use the dashboss as a monitoring system. All of my temps and pressures were fine at the time I started having the problem, but this is what happened, I was driving at highway speeds, around 65, I put my foot into the throttle a little harder and that's when it happened, kinda like a miss and then a sorta knocking noise, shaking and loss of power with a mix of white and black smoke coming out the back pipe. I would try to get back up to speed but when ever I put my foot in it just a little the truck starts shaking pretty bad and a lot of white smoke out of the back. I just had the egr cooler replace about 3 weeks ago and I added the ipr coolant filter to the truck along with a switch to rotella ultra elc. I haven't noticed a loss in coolant at all so I don't think it is the egr cooler. I hope this helps.
2006 Ford F250
ARP studs
EGR Delete
IPR Coolant filter
S&B Cold air intake
8" suspension lift
