degas pressure need advice - Ford Powerstroke Diesel Forum
post #1 of 5 Old 10-20-2013, 10:32 AM Thread Starter
The truck in last 15 000 miles has new ford heads with stock gaskets and arps egr bypass and oil new cooler. Its getting cold here so I was installing new oe ford injectors and noticed some white residue near rhe degas cap so I replaced the cap last weekend. 300 miles later i have a touch more degas white residue.
I just hooked up a pressure gauage and between full throttle and a degas psi increase only happened once out of ten full trottle runs. That time though it did get up around 17 psi. The rest of the time it seams to set itself at about 7.5 psi not caring on how its driven.
sam_sso is offline
post #2 of 5 Old 10-20-2013, 11:02 AM Thread Starter
btw when i did injectors it sat parked for a day to to rain and when i removed a small hose from the degas it had pressure still after 2 days of sitting
sam_sso is offline
post #3 of 5 Old 10-21-2013, 08:49 PM
I heard the theory that under heavy load the heads can lift and raise the coolant pressure, that will stay good under lower loads.
But this is extreme theory and you might have several other issues before come to this conclusion.
What is your delta?
2007 F350 dually/5000 lb, 12' tall camper.
Kajtek1 is offline
post #4 of 5 Old 10-26-2013, 10:45 PM
What is your ratio? I noticed with elc that I was running about 43/57 and the coolant was flash boiling making pressure, and now with 65/35 its fine. Just my two cents
468 HP & 873 Ft-Lbs
2005 F-350 SRW 4x4 CC Long Bed
SPD tune by Chris @ Truck Source Diesel
ARP Head Studs
3.5" DP to 4" Straight Pipe
Banks High Ram Air Intake
K&N CAI
Edge Evo CTS w/ Backup Camera to monitor
MTS HD Direct Drive Solenoid
Updated:
Standpipe & dummy plugs
Turbo feed & drain tubes
HPOP & IPR screens
Blue Spring
ajfrac is offline
post #5 of 5 Old 10-27-2013, 06:41 AM
Quoted: 50 Post(s)
Were the new heads checked for flatness? Ford heads are notoriously not flat.
I had a similar issue before I studded. Under a load I could see 22 psi in the cooling system, and the cap would vent as it's supposed to. Now I see 7 - 8 psi coolant pressure, which is just the temperature fluid expansion pressure.
2016 F350 CCSB 4x4 6.7 FX4 Lariat Ultimate
Ruby Red with Black Leather
3.55s, OEM 20s, Locking Rear Diff
Icon 2.5 CDC Shocks
TufTrucks 2.5" 7,500 lb coils
Carli Track Bar
Carli High Mount Stabilizer
Titan 50g Midship Tank
295/65/20 Nitto Ridge Grapplers
Previous:
2006 F250 CCSB 4x4 6.0 FX4 Lariat Ultimate
All the BPD goodies
skanj0 is offline
