F250 6.0 idling up & down at stop! - Ford Powerstroke Diesel Forum
post #1 of 7 Old 10-20-2013, 07:10 AM Thread Starter
I hope someone can tell me what is going on with my truck. It is a 2005, F250, FX4 with a 6.0 stock engine that has just rolled over 100000 miles. It started idling up & dropping when I would be at a stop with no hesitating at take off & ran well. I would have to make sure I had the brakes on or it would surge forward when this would happen. It is a intermitting problem but starting to happen more often. (I have changed the fuel filters thinking that might be the problem but it hasn't) This has been going on for about a month, it is now starting to do this riding down the road, you can see the RPM guage moving up and down irregular, just starting to do this. Not sure where to look first! Your help would be appreciated!
Thanks,
Mrbrez
2005 F250 FX4
Mrbrez
mrbrez is offline
post #2 of 7 Old 10-20-2013, 07:42 AM
DoubleDpsd's Avatar
ICP. .
2003 centennial edition f250 4x4 ccsb auto w/blackwater long block w/arp's, 4" exhaust, airaid intake, ODawg's manifold, itp's reg return, sap modified solenoid, DC power 185amp alt, motorcraft 850cca, Warn Hubs, RS 55w 6k hid's, harley headlights, bpd 58v 6 phase, bpd water pump, dieselsite coolant filter, elc coolant, php gryphon, Xcal2 w/unlimited tow, new hfcm, glowshift fuel psi gauge, icon level kit, 20" kmc hoss, 305/55 terra grapplers TOTALED
DoubleDpsd is offline
post #3 of 7 Old 10-20-2013, 09:11 AM
I was having the same problem with my 05 f-250. For several months I went back and forth to a mechanic. The code i got was torque converter solenoid, however after changing the soledoid the problem was not fixed. I ended up borrowing a monitor from a friend and to my unhappy surprise i had 40 deg. delta on EOC/ECT. Back to the original problem, I had a ruptured EGR cooler causing the surging.
Keith Stark is offline
post #4 of 7 Old 10-21-2013, 12:16 PM
Fummins90's Avatar
Does it smoke while it surges?
-Jacob
PowerHungryPerformance --
Comments or opinions expressed by me do not necessarily represent the views of PHP, its management, nor its employees. PHP is not responsible for, and disclaims any and all liability for the content of comments written by me.
Fummins90 is offline
post #5 of 7 Old 10-21-2013, 05:24 PM Thread Starter
No smoke when this happens!
Mrbrez
mrbrez is offline
post #6 of 7 Old 10-21-2013, 05:44 PM
Maxxforce365's Avatar
Quoted: 14 Post(s)
Sounds Like an ICP sensor. Pull The pigtail on Thr sensor and inspect for rubbing wires or oil on the connector. Replace the sensor if it has oil.
Instagram@platinum_forces
2015 Platinum F350 CCLB[/B]
EPA Delete Tuned by PIP
Fabtech 12" 4 Link Airdog II
04.5 F350 CCLB 4/04-7/25/15
MTW S2 Warren 175/30s Tuned by Gearhead
ARPs with OEM gaskets
Sinister Regulated Return AirDog II Beans sump
2012 Door Panels Fully Functional
Warn 12k winch
Fab Fours Front and Rear bumpers
Maxxforce365 is offline
post #7 of 7 Old 10-21-2013, 05:52 PM
I had the same problem, changed the ICP connector pig tail and no more problem.
NEredeye is offline
