06 6.0 nusence problem - Ford Powerstroke Diesel Forum
post #1 of 3 Old 10-19-2013, 10:30 AM Thread Starter
Hello all,
I am working on a 2006 6.0. It's got 228,xxx on it. I put an HPOP on it with all the goodies on it about 10,000 miles ago. Customer has brought it back this week saying all the sudden it will run great, you'll go park and go in somewhere for 10-15 minutes and come back and it won't start for several hours. I've searched high and low and can't seem to find anything wrong. When it goes into it's tiff it will crank fine, ficm voltage is like 49, synced, and Desired and actual icp are at like 490-550 depending on when my genisys refreshes. It has a couple codes in it for 2-4 glow plugs circut and a egr code. Does anyone know where to start on this??
Any thoughts, comments, ect are much appreciated.
Thanks!!
Sent from AutoGuide.com App
2012 F-250 6.7 Powerstroke ATS Aurora 4000 Turbo, S&B Cold Air Intake with Dry Filter, No Limit Fab EGR Blocker Plates, 5" Flo-Pro Exhaust without Muffler, EZLYNK from PPEI
Yellow Rose Diesel, Amarillo TX
Pcfr108 is offline
post #2 of 3 Old 10-19-2013, 10:54 AM
Mod Newbie
dhanna6powerstroke's Avatar
Quoted: 19 Post(s)
It has an HPO leak somewhere.
dhanna6powerstroke is offline
post #3 of 3 Old 10-19-2013, 12:11 PM
Re air test yourHPO system you may have nicked an o-ring or the stc had some damage that is only now showing up.
Also check your fuel pressure/volume.
Lord I shall lead them to the water but I will not try to make them drink
dannyboy950 is offline
